- To:
- Subject: Re: [cgal-discuss] polygon intersection problem
- Date: Tue, 17 Apr 2012 17:50:04 +0200
well you might want to double check my file, but I don't see any degenerate segment in my polygons. But I thought about it, maybe it was a problem at the junction between first and last points, so I skipped a few points at the end when reading the file, and I still have this problem. I must add that this configuration works fine when I use GEOS.
I didn't specified my system : Visual Studio 2010 on win XP, if it's of any help.
2012/4/17 Sebastien Loriot (GeometryFactory) <>
On 04/17/2012 05:17 PM, Jasmin Formont wrote:without looking at the file, it is highly probable that you have a
File : C:\Program
Files\CGAL-4.0\include\CGAL\Arr_segment_traits_2.h
Line : 127
Explanation: cannot construct a degenerate segment
segment made of two identical points.
Sebastien.
- [cgal-discuss] polygon intersection problem, Jasmin Formont, 04/17/2012
- Re: [cgal-discuss] polygon intersection problem, Sebastien Loriot (GeometryFactory), 04/17/2012
- Re: [cgal-discuss] polygon intersection problem, Jasmin Formont, 04/17/2012
- Re: [cgal-discuss] polygon intersection problem, Sebastien Loriot (GeometryFactory), 04/18/2012
