- To:
- Subject: Re: [cgal-discuss] polygon intersection problem
- Date: Wed, 18 Apr 2012 13:36:22 +0200
Can you provide the code used? or at least the polygons in a human readable format (the reader I tried could not read the file).
Sebastien.
On 04/17/2012 05:50 PM, Jasmin Formont wrote:
well you might want to double check my file, but I don't see any
degenerate segment in my polygons. But I thought about it, maybe it was
a problem at the junction between first and last points, so I skipped a
few points at the end when reading the file, and I still have this
problem. I must add that this configuration works fine when I use GEOS.
I didn't specified my system : Visual Studio 2010 on win XP, if it's of
any help.
2012/4/17 Sebastien Loriot (GeometryFactory)
<mailto:>>
On 04/17/2012 05:17 PM, Jasmin Formont wrote:
File : C:\Program
Files\CGAL-4.0\include\CGAL\__Arr_segment_traits_2.h
Line : 127
Explanation: cannot construct a degenerate segment
without looking at the file, it is highly probable that you have a
segment made of two identical points.
Sebastien.
https://lists-sop.inria.fr/__wws/info/cgal-discuss
<https://lists-sop.inria.fr/wws/info/cgal-discuss>
- [cgal-discuss] polygon intersection problem, Jasmin Formont, 04/17/2012
- Re: [cgal-discuss] polygon intersection problem, Sebastien Loriot (GeometryFactory), 04/17/2012
- Re: [cgal-discuss] polygon intersection problem, Jasmin Formont, 04/17/2012
- Re: [cgal-discuss] polygon intersection problem, Sebastien Loriot (GeometryFactory), 04/18/2012
