cgal-discuss - Re:[cgal-discuss] Getting the following error: CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external symbol
  • To:
  • Subject: Re:[cgal-discuss] Getting the following error: CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external symbol
  • Date: Mon, 23 Apr 2012 08:37:39 +0800 (CST)
I don't know if my point is right. CGAL-vc80-mt-gd.lib is only for vs2005,not for 2010.maybe you'd change cgal version to newer in order to support vs2010. just a suggest. I am using vs2008,and the lib is CGAL-vc90-mt-gd.lib,this may be the right things to do .
Wish you good luck!
At 2012-04-23 03:24:04, wrote: >Hi, > >  I am new to CGAL and boost. I have installed Microsoft Visual Studio 2010 >Professional, Cgal 3.3.1 and Boost_1_47. I am working on Windows 7 64 bit. I >have installed cgal and boost in a folder on my desktop. The environment >variables have been set correctly. Initially I was getting an error: > >.....\include\CGAL/Root_of_traits.h(65): error C2338: >(FrT::Is_fraction::value). After searching, I found out that >"BOOST_STATIC_ASSERT((FrT::Is_fraction::value))" needed to be replaced with  > >typedef typename FrT::Is_fraction ISF; > BOOST_STATIC_ASSERT((ISF::value)); > >The error was resolved but the following new errors were encountered: > >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : warning LNK4049: locally defined symbol >?length@?$char_traits@D@std@@SAIPBD@Z (public: static unsigned int __cdecl >std::char_traits<char>::length(char const *)) imported >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: __thiscall std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >(class >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >> const &)" >(__imp_??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@ABV01@@Z) >referenced in function "public: __thiscall std::logic_error::logic_error(class >std::logic_error const &)" (??0logic_error@std@@QAE@ABV01@@Z) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2001: unresolved external symbol >"__declspec(dllimport) public: __thiscall std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >(class >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >> const &)" >(__imp_??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@ABV01@@Z) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> > __cdecl >std::operator+<char,struct std::char_traits<char>,class std::allocator<char> >>(class std::basic_string<char,struct std::char_traits<char>,class >std::allocator<char> > const &,class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> > const &)" >(__imp_??$?HDU?$char_traits@D@std@@V?$allocator@D@1@@std@@YA?AV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@0@ABV10@0@Z) >referenced in function "public: __thiscall >CGAL::Failure_exception::Failure_exception(class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >,class >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >>,class std::basic_string<char,struct std::char_traits<char>,class >std::allocator<char> >,int,class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >,class >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >>)" >(??0Failure_exception@CGAL@@QAE@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@00H00@Z) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: bool __thiscall >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >>::empty(void)const " >(__imp_?empty@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBE_NXZ) >referenced in function "public: __thiscall >CGAL::Failure_exception::Failure_exception(class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >,class >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >>,class std::basic_string<char,struct std::char_traits<char>,class >std::allocator<char> >,int,class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >,class >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >>)" >(??0Failure_exception@CGAL@@QAE@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@00H00@Z) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: __thiscall std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >(struct >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >>::_Has_debug_it)" >(__imp_??0?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@U_Has_debug_it@01@@Z) >referenced in function "class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> > __cdecl >boost::lexical_cast<class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >,int>(int const &)" >(??$lexical_cast@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@boost@@YA?AV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@ABH@Z) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: int __thiscall std::ios_base::width(int)" >(__imp_?width@ios_base@std@@QAEHH@Z) referenced in function "class >std::basic_ostream<char,struct std::char_traits<char> > & __cdecl >std::operator<<<struct std::char_traits<char> >(class >std::basic_ostream<char,struct std::char_traits<char> > &,char const *)" >(??$?6U?$char_traits@D@std@@@std@@YAAAV?$basic_ostream@DU?$char_traits@D@std@@@0@AAV10@PBD@Z) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2001: unresolved external symbol >"__declspec(dllimport) public: int __thiscall std::ios_base::width(int)" >(__imp_?width@ios_base@std@@QAEHH@Z) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: int __thiscall >std::basic_streambuf<char,struct std::char_traits<char> >::sputn(char const >*,int)" >(__imp_?sputn@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAEHPBDH@Z) >referenced in function "class std::basic_ostream<char,struct >std::char_traits<char> > & __cdecl std::operator<<<struct >std::char_traits<char> >(class std::basic_ostream<char,struct >std::char_traits<char> > &,char const *)" >(??$?6U?$char_traits@D@std@@@std@@YAAAV?$basic_ostream@DU?$char_traits@D@std@@@0@AAV10@PBD@Z) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2001: unresolved external symbol >"__declspec(dllimport) public: int __thiscall std::basic_streambuf<char,struct >std::char_traits<char> >::sputn(char const *,int)" >(__imp_?sputn@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAEHPBDH@Z) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: static bool __cdecl >std::char_traits<char>::eq_int_type(int const &,int const &)" >(__imp_?eq_int_type@?$char_traits@D@std@@SA_NABH0@Z) referenced in function >"class std::basic_ostream<char,struct std::char_traits<char> > & __cdecl >std::operator<<<struct std::char_traits<char> >(class >std::basic_ostream<char,struct std::char_traits<char> > &,char const *)" >(??$?6U?$char_traits@D@std@@@std@@YAAAV?$basic_ostream@DU?$char_traits@D@std@@@0@AAV10@PBD@Z) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2001: unresolved external symbol >"__declspec(dllimport) public: static bool __cdecl >std::char_traits<char>::eq_int_type(int const &,int const &)" >(__imp_?eq_int_type@?$char_traits@D@std@@SA_NABH0@Z) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: static int __cdecl >std::char_traits<char>::eof(void)" (__imp_?eof@?$char_traits@D@std@@SAHXZ) >referenced in function "class std::basic_ostream<char,struct >std::char_traits<char> > & __cdecl std::operator<<<struct >std::char_traits<char> >(class std::basic_ostream<char,struct >std::char_traits<char> > &,char const *)" >(??$?6U?$char_traits@D@std@@@std@@YAAAV?$basic_ostream@DU?$char_traits@D@std@@@0@AAV10@PBD@Z) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2001: unresolved external symbol >"__declspec(dllimport) public: static int __cdecl >std::char_traits<char>::eof(void)" (__imp_?eof@?$char_traits@D@std@@SAHXZ) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: int __thiscall >std::ios_base::width(void)const " (__imp_?width@ios_base@std@@QBEHXZ) >referenced in function "class std::basic_ostream<char,struct >std::char_traits<char> > & __cdecl std::operator<<<struct >std::char_traits<char> >(class std::basic_ostream<char,struct >std::char_traits<char>> &,char const *)" >(??$?6U?$char_traits@D@std@@@std@@YAAAV?$basic_ostream@DU?$char_traits@D@std@@@0@AAV10@PBD@Z) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2001: unresolved external symbol >"__declspec(dllimport) public: int __thiscall std::ios_base::width(void)const " >(__imp_?width@ios_base@std@@QBEHXZ) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: void __thiscall >std::basic_streambuf<char,struct std::char_traits<char> >::_Lock(void)" >(__imp_?_Lock@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAEXXZ) referenced >in function "public: __thiscall std::basic_ostream<char,struct >std::char_traits<char> >::_Sentry_base::_Sentry_base(class >std::basic_ostream<char,struct std::char_traits<char> > &)" >(??0_Sentry_base@?$basic_ostream@DU?$char_traits@D@std@@@std@@QAE@AAV12@@Z) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2001: unresolved external symbol >"__declspec(dllimport) public: void __thiscall std::basic_streambuf<char,struct >std::char_traits<char> >::_Lock(void)" >(__imp_?_Lock@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAEXXZ) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: void __thiscall >std::basic_streambuf<char,struct std::char_traits<char> >::_Unlock(void)" >(__imp_?_Unlock@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAEXXZ) >referenced in function "public: __thiscall std::basic_ostream<char,struct >std::char_traits<char> >::_Sentry_base::~_Sentry_base(void)" >(??1_Sentry_base@?$basic_ostream@DU?$char_traits@D@std@@@std@@QAE@XZ) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2001: unresolved external symbol >"__declspec(dllimport) public: void __thiscall std::basic_streambuf<char,struct >std::char_traits<char> >::_Unlock(void)" >(__imp_?_Unlock@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAEXXZ) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: void __thiscall >std::basic_stringstream<char,struct std::char_traits<char>,class >std::allocator<char> >::`vbase destructor'(void)" >(__imp_??_D?$basic_stringstream@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEXXZ) >referenced in function >__unwindfunclet$??0?$lexical_stream@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@detail@boost@@QAE@XZ$0 >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: int __thiscall >std::ios_base::precision(int)" (__imp_?precision@ios_base@std@@QAEHH@Z) >referenced in function "public: __thiscall boost::detail::lexical_stream<class >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >>,int>::lexical_stream<class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >,int>(void)" >(??0?$lexical_stream@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@detail@boost@@QAE@XZ) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: __thiscall >std::basic_stringstream<char,struct std::char_traits<char>,class >std::allocator<char> >::basic_stringstream<char,struct >std::char_traits<char>,class std::allocator<char> >(int)" >(__imp_??0?$basic_stringstream@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAE@H@Z) >referenced infunction "public: __thiscall boost::detail::lexical_stream<class >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >>,int>::lexical_stream<class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >,int>(void)" >(??0?$lexical_stream@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@detail@boost@@QAE@XZ) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> > & __thiscall >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >>::operator=(class std::basic_string<char,struct std::char_traits<char>,class >std::allocator<char> > const &)" >(__imp_??4?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QAEAAV01@ABV01@@Z) >referenced in function "public: bool __thiscall >boost::detail::lexical_stream<class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >,int>::operator>>(class >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >> &)" >(??5?$lexical_stream@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@detail@boost@@QAE_NAAV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) >9>CGAL-vc80-mt-gd.lib(assertions.obj) : error LNK2019: unresolved external >symbol "__declspec(dllimport) public: class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> > __thiscall >std::basic_stringstream<char,struct std::char_traits<char>,class >std::allocator<char> >::str(void)const " >(__imp_?str@?$basic_stringstream@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBE?AV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@2@XZ) >referenced in function "public: bool __thiscall >boost::detail::lexical_stream<class std::basic_string<char,struct >std::char_traits<char>,class std::allocator<char> >,int>::operator>>(class >std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >> &)" >(??5?$lexical_stream@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@detail@boost@@QAE_NAAV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2019: unresolved external symbol >"__declspec(dllimport) public: void __thiscall >std::_Container_base::_Orphan_all(void)const " >(__imp_?_Orphan_all@_Container_base@std@@QBEXXZ) referenced in function >"public: class std::vector<short,class std::allocator<short> > & __thiscall >std::vector<short,class std::allocator<short> >::operator=(class >std::vector<short,class std::allocator<short> > const &)" >(??4?$vector@FV?$allocator@F@std@@@std@@QAEAAV01@ABV01@@Z) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2019: unresolved external symbol >"__declspec(dllimport) public: __thiscall >std::_Container_base::~_Container_base(void)" >(__imp_??1_Container_base@std@@QAE@XZ) referenced in function "public: >__thiscall std::_Vector_val<short,class std::allocator<short> >>::~_Vector_val<short,class std::allocator<short> >(void)" >(??1?$_Vector_val@FV?$allocator@F@std@@@std@@QAE@XZ) >9>CGAL-vc80-mt-gd.lib(MP_Float.obj) : error LNK2019: unresolved external symbol >"__declspec(dllimport) public: __thiscall >std::_Container_base::_Container_base(void)" >(__imp_??0_Container_base@std@@QAE@XZ) referenced in function "protected: >__thiscall std::_Vector_val<short,class std::allocator<short> >>::_Vector_val<short,class std::allocator<short> >(class >std::allocator<short>)" >(??0?$_Vector_val@FV?$allocator@F@std@@@std@@IAE@V?$allocator@F@1@@Z) >9>Debug\adding_handles.exe : fatal error LNK1120: 19 unresolved externals > >I tried including the boost's lib path to the project's >properties->linker->additional directories, but to no avail. > >Can someone suggest some solutions? > >Cheers, >Shaoli > >--  >You are currently subscribed to cgal-discuss. >To unsubscribe or access the archives, go to >https://lists-sop.inria.fr/wws/info/cgal-discuss >
网易Lofter,专注兴趣,分享创作!
