cgal-discuss - Re: [cgal-discuss] Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10
  • To:
  • Subject: Re: [cgal-discuss] Problems making CGAL demos - libQtOpenGL - on Ubuntu 11.10
  • Date: Mon, 23 Apr 2012 08:43:37 +0200
You need to install libqt4-opengl-dev
(apt-file find /usr/lib/libQtOpenGL.so is giving you the name of the
missing package)
Sebastien.
On 04/23/2012 01:40 AM, stupormundi wrote:
Hi List!
I have installed the CGAL from ppa, on Ubuntu 11.10, gnome 3, xubuntu, 64
bit, running on intel 1155. The CGAL version number is 3.8-1.
I've made some progress making the examples by installing various libs cmake
was flagging up.
No luck with the demos though. Regarding dependence on libQtOpenGL,
apparently the CGAL cmake mechanism switches between the QT3 and QT4 version
depending on what's available, so I've tried to install only the QT4 bits so
as not to confuse it.
I have installed :
libqglviewer-dev-common
libqglviewer-qt4-dev
libqglviewer-qt4-2
and NOT installed :
libqglviewer2
libqglviewer-dev
libqglviewer-qt3-dev
libqglviewer-qt3-2
From the naming, it looked as if I should maybe install libqglviewer2 and
libqglviewer-dev, but the descriptions seems to indicate they are there for
transition to QT3 (from QT2 ? ), but maybe I'm misunderstanding those.
What I find confusing, while the description would indicate I should have
libqglviewer-dev-common , there is some mention of QT3 in there. But there
doesn't seem to be another dev-common lib with reference to QT4.
I've used Synaptic to install those.
Anyway, when running make I get :
make[2]: *** No rule to make target `/usr/lib/libQtOpenGL.so', needed by
`AABB_tree/AABB_demo'. Stop.
make[1]: *** [AABB_tree/CMakeFiles/AABB_demo.dir/all] Error 2
make: *** [all] Error 2
This happens for all of the demos, they all seem to need libQtOpenGL.
Did I install the wrong bits?
my version for the libs is 2.3.4-4ubuntu1
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problems-making-CGAL-demos-libQtOpenGL-on-Ubuntu-11-10-tp4579052p4579052.html
