- To:
- Subject: Re: [cgal-discuss] Using boundaries on Mesh_domain
- Date: Tue, 24 Apr 2012 08:27:34 +0200
Why don't you count it yourself?it's only one iteration
On Apr 24, 2012 3:29 AM, "Francesc" <> wrote:
I am trying to use Mesh_domain with a custom function to generate the mesh of
a volumetric image, is there any way to force the bounding box to be
represented on the mesh?
Thank you,
F
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Using-boundaries-on-Mesh-domain-tp4582171p4582171.html
- [cgal-discuss] Using boundaries on Mesh_domain, Francesc, 04/24/2012
- Re: [cgal-discuss] Using boundaries on Mesh_domain, Zoltán Váradi, 04/24/2012
- Re: [cgal-discuss] Using boundaries on Mesh_domain, Sebastien Loriot (GeometryFactory), 04/25/2012
