- To:
- Subject: Re: [cgal-discuss] Re: Finding an averaging curve though a set of points in 3D
- Date: Fri, 27 Apr 2012 09:35:01 +0200
remeshing with the polyline as sharp feature will preserve the
polyline as it is, with no smoothing... One solution might be to apply a smoothing process, Laplacian or other convolution base process on the polyline, and remesh using the new smoother polyline as sharp features. Remeshing volumes and surfaces with sharp features tolerate the fact that the sharp feature might not be exactly on the surfaces. Le 26/04/12 16:38, Sebastien Loriot (GeometryFactory) a écrit : I read your question too fast, I thought you simply wanted to close the -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Finding an averaging curve though a set of points in 3D, Oleg, 04/23/2012
- Re: [cgal-discuss] Finding an averaging curve though a set of points in 3D, Sebastien Loriot (GeometryFactory), 04/24/2012
- [cgal-discuss] Re: Finding an averaging curve though a set of points in 3D, Oleg, 04/25/2012
- [cgal-discuss] Re: Finding an averaging curve though a set of points in 3D, Oleg, 04/26/2012
- Re: [cgal-discuss] Re: Finding an averaging curve though a set of points in 3D, Sebastien Loriot (GeometryFactory), 04/26/2012
- Re: [cgal-discuss] Re: Finding an averaging curve though a set of points in 3D, Mariette Yvinec, 04/27/2012
