cgal-discuss - [cgal-discuss] Re: Finding an averaging curve though a set of points in 3D
  • To:
  • Subject: [cgal-discuss] Re: Finding an averaging curve though a set of points in 3D
  • Date: Wed, 25 Apr 2012 04:12:22 -0700 (PDT)
Sebastien Loriot (GeometryFactory) wrote
> You can use the part of the other surface bounded by the curve.
> For example, if you have two spheres intersecting along a circle, you'll
> have a sphere with a crater.
Do you mean meshing domains with sharp features?
Oleg
> On 04/23/2012 01:40 PM, Oleg wrote:
>> Hello everyone! I have a set of points in 3D as the result of calculating
>> intersection of two triangulated 3D figures. Since they are calculated as
>> intersection of individual triangles of the two meshes, they form a
>> rather
>> rough polyline. Are there any means in CGAL to smooth it over? The goal
>> is
>> to obtain a smooth sharp curve of intersection of two 3D figures.
>> Oleg
>> View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/Finding-an-averaging-curve-though-a-set-of-points-in-3D-tp4580170p4580170.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
http://cgal-discuss.949826.n4.nabble.com/Finding-an-averaging-curve-though-a-set-of-points-in-3D-tp4580170p4586260.html
