cgal-discuss - Re: [cgal-discuss] Facet soup to solids
  • To: "" <>
  • Subject: Re: [cgal-discuss] Facet soup to solids
  • Date: Tue, 8 May 2012 10:59:20 -0700
Would taking the union without regularizing the result do what you need?
On May 8, 2012, at 10:38 AM, GIS Worx
wrote:
> Hi everyone,
> I've spent quite a bit of time reading documentation and trying to devise a
> way to accomplish the following:
> Given a bag of planar facets, seal them, where possible, into closed
> polyhedrons, and return the remnants, as well as the newly constructed
> polyhedrons.
> Reading the Polyhedron_3 and Nef_Polyhedron documentation, it seems like
> the approach that comes closest is this:
> Use Nef_Polyhedron to define each facet, and then take the union of every
> facet, then the closed volumes can be marked and it's possible to iterate
> through the results. My problem with this method is that it will remove
> 'seams' between solids according to the union operation.
> If you imagine a two cubes, side by side, each defined by six faces, I
> would like two cubes back, each represented by six faces, not a single
> unified solid.
> I am not immediately concerned with performance, which can be solved
> externally to this particular problem.
> Is there a pathway to accomplish this within CGAL that I am missing? Is
> there a way to 'merge' two Nef_Polyhedra in a way that will maintain shared
> faces?
