cgal-discuss - Re: [cgal-discuss] Facet soup to solids
  • To:
  • Subject: Re: [cgal-discuss] Facet soup to solids
  • Date: Wed, 09 May 2012 08:40:39 +0200
Do you have a minimal example to share?
I am not sure to fully understand what your input are.
Is the facet shared by your cubes perfectly match (in term of
coordinates of the vertices) in each cube?
Could you have some dangling edges later on?
Do you have some boolean operation to do on this structure then
of is it simply to navigate inside?
I am asking these questions because you might be interested by these packages:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Linear_cell_complex/Chapter_main.html
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Combinatorial_map/Chapter_main.html
Sebastien.
On 05/09/2012 12:38 AM, GIS Worx wrote:
Thank you for the suggestion Cody.
So I've attempted to construct a simple example, with two unit cubes,
constructing each using the Nef_polyhedra constructor that takes a
boundary and a normal as a separate Nef polyhedron, and then adding it
to a Nef_nary_union_3. Looking at the methods in this class, it doesn't
appear that any calls to .simplify() are made, I would assume this is
what you mean by regularizing the result.
However, inspecting the result of the Nef_nary_union of these 12 faces
defining two cubes (which are touching along a face), I see
number_of_facets() = 6 and number_of_volumes() = 2. Based on the manual
descriptions, I would hope to see the answers here be 12, and 4, so that
I have two independent cubes in the result.
There doesn't seem to be anything I can do to prevent the loss of that
shared face.
On Tue, May 8, 2012 at 10:59 AM, Cody Rose
<mailto:>>
wrote:
Would taking the union without regularizing the result do what you need?
On May 8, 2012, at 10:38 AM, GIS Worx
<mailto:>>
wrote:
> Hi everyone,
> I've spent quite a bit of time reading documentation and trying
to devise a way to accomplish the following:
> Given a bag of planar facets, seal them, where possible, into
closed polyhedrons, and return the remnants, as well as the newly
constructed polyhedrons.
> Reading the Polyhedron_3 and Nef_Polyhedron documentation, it
seems like the approach that comes closest is this:
> Use Nef_Polyhedron to define each facet, and then take the union
of every facet, then the closed volumes can be marked and it's
possible to iterate through the results. My problem with this method
is that it will remove 'seams' between solids according to the union
operation.
> If you imagine a two cubes, side by side, each defined by six
faces, I would like two cubes back, each represented by six faces,
not a single unified solid.
> I am not immediately concerned with performance, which can be
solved externally to this particular problem.
> Is there a pathway to accomplish this within CGAL that I am
missing? Is there a way to 'merge' two Nef_Polyhedra in a way that
will maintain shared faces?
