cgal-discuss - Re: [cgal-discuss] Re: How to get some info from a Delaunay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Re: How to get some info from a Delaunay Triangulation
  • Date: Wed, 09 May 2012 14:35:41 +0200
On 05/09/2012 02:21 PM, horstmann wrote:
Hi Sebastien,
thanks for your fast and accurate answer.
I'm still a bit confused whit the second parameter.
- for each tetrahedron, the position of its four vertices (in ascending
order).
Triangulation::Cell_handle cell=....
cell->vertex(i).point(); //for i=0; i<4
cf [2,3]
When you say "Triangulation::Cell_handle cell=.... " What should I assign to
'cell'?
I guess I need an iterator over finite_cells, don't I ?
At this moment I'm doing this:
typedef CGAL::Exact_predicates_inexact_constructions_kernel
K;
typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, K>
Vb;
typedef CGAL::Triangulation_data_structure_3<Vb>
Tds;
typedef CGAL::Triangulation_3<K, Tds>::Cell_handle
Cell_handle;
Cell_handle cell = ... ?? ;
Delaunay::Finite_cells_iterator fit;
for(fit = dt.finite_cells_begin() ; fit != dt.finite_cells_end() ;
fit++,
i++)
for(i=0;i<4;i++)
fit->vertex(i).point() will work.
Sebastien.
Is all of that correct? What am I missing?
Thank you again so much !!
EDU.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-get-some-info-from-a-Delaunay-Triangulation-tp4617393p4620270.html
