- To:
- Subject: Re: [cgal-discuss] Re: How to get some info from a Delaunay Triangulation
- Date: Wed, 09 May 2012 14:41:58 +0200
On 09/05/2012 14:35, Sebastien Loriot (GeometryFactory) wrote:
On 05/09/2012 02:21 PM, horstmann wrote:
Hi Sebastien,fit->vertex(i).point() will work.
thanks for your fast and accurate answer.
I'm still a bit confused whit the second parameter.
- for each tetrahedron, the position of its four vertices (in ascending
order).
Triangulation::Cell_handle cell=....
cell->vertex(i).point(); //for i=0; i<4
cf [2,3]
When you say "Triangulation::Cell_handle cell=.... " What should I
assign to
'cell'?
I guess I need an iterator over finite_cells, don't I ?
At this moment I'm doing this:
typedef CGAL::Exact_predicates_inexact_constructions_kernel
K;
typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, K>
Vb;
typedef CGAL::Triangulation_data_structure_3<Vb>
Tds;
typedef CGAL::Triangulation_3<K, Tds>::Cell_handle Cell_handle;
Cell_handle cell = ... ?? ;
Delaunay::Finite_cells_iterator fit;
for(fit = dt.finite_cells_begin() ; fit != dt.finite_cells_end() ; fit++,
i++)
for(i=0;i<4;i++)
Note that it is often helpful to look at the manual page of the
base class. As a Delaunay_triangulation_3 is a Triangulation_3
you find the types here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html#Cross_link_anchor_1363
together with the following sentence:
Iterators and circulators are convertible to the corresponding handles, thus the user can pass them directly as arguments to the functions.
andreas
Sebastien.
Is all of that correct? What am I missing?
Thank you again so much !!
EDU.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-get-some-info-from-a-Delaunay-Triangulation-tp4617393p4620270.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] How to get some info from a Delaunay Triangulation, horstmann, 05/08/2012
- Re: [cgal-discuss] How to get some info from a Delaunay Triangulation, Sebastien Loriot (GeometryFactory), 05/09/2012
- Re: [cgal-discuss] How to get some info from a Delaunay Triangulation, Olivier Devillers, 05/09/2012
- [cgal-discuss] Re: How to get some info from a Delaunay Triangulation, horstmann, 05/09/2012
- Re: [cgal-discuss] Re: How to get some info from a Delaunay Triangulation, Sebastien Loriot (GeometryFactory), 05/09/2012
- Re: [cgal-discuss] Re: How to get some info from a Delaunay Triangulation, Andreas Fabri, 05/09/2012
- Re: [cgal-discuss] Re: How to get some info from a Delaunay Triangulation, Philipp Moeller, 05/09/2012
- Re: [cgal-discuss] Re: How to get some info from a Delaunay Triangulation, J.S. van Bethlehem, 05/09/2012
- [cgal-discuss] Re: How to get some info from a Delaunay Triangulation, horstmann, 05/10/2012
