cgal-discuss - [cgal-discuss] Triangulation: "global" Cell's order , and Cell_handle comparation
  • To:
  • Subject: [cgal-discuss] Triangulation: "global" Cell's order , and Cell_handle comparation
  • Date: Fri, 11 May 2012 06:08:57 -0700 (PDT)
Hi everyone!
If I had a triangulation as follows:
std::vector<Point> P;
for(i=0;i<*nsphere;i++)
// Add point to triangulation
P.push_back(Point(coord[pos],coord[pos+1],coord[pos+2]));
Delaunay dt(P.begin(), P.end());
1. Then, is there a "global" order of the Finite_Cells respect to the whole
triangulation¿?
i.e., a global index of each Finite_Cell between the range [0 ,
dt.number_of_finite_cells()-1 ]
Is it possible to get that index?¿
2. Is it possible to compare two Cell_handle's as pointers, in order to know
if they point to the same cell¿?
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Delaunay_triangulation_3<K, CGAL::Fast_location>
Delaunay;
typedef Delaunay::Cell_handle Cell_handle;
Cell_handle ch1,ch2;
... assign someything
* if (ch1 == ch2) ....... *
Does it make sense??
If not, is it possible to compare to cell's ?¿
Thanks a lot in advance!!
EDU
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangulation-global-Cell-s-order-and-Cell-handle-comparation-tp4626363.html
