- To:
- Subject: Re: [cgal-discuss] Different Mesh Criteria for Subdomains
- Date: Tue, 29 May 2012 10:43 +0200
Le jeudi 24 mai 2012 10:54:36 slaughter a écrit :
> I am following section "50.3.4 Using Variable Sizing Field : Different
> Sizing Field for Different Subdomains," but can't seem to get this approach
> to work for any other of the Mesh critiera besides the cell_size. Is it
> possible to vary all of the mesh criteria based on the subdomain_index, if
> so how is this done?
That is possible but not strait-forward. You will have to implement a model
of
the concept MeshCellCriteria_3 yourself. You can try to read the source code
of <CGAL/Mesh_cell_criteria_3.h>, and adapt it to your needs.
By curiosity, what sort of cell criteria, besides the cell_size, would you
like to make dependent on the subdomain_index? Maybe you needs are general
and
should be in the features of CGAL meshers.
Laurent Rineau, PhD
- [cgal-discuss] Different Mesh Criteria for Subdomains, slaughter, 05/24/2012
- Re: [cgal-discuss] Different Mesh Criteria for Subdomains, Laurent Rineau (CGAL/GeometryFactory), 05/29/2012
- [cgal-discuss] Re: Different Mesh Criteria for Subdomains, slaughter, 05/29/2012
