- From: Marius Kintel <(005b7a4cd6%hidden_head%005b7a4cd6)marius(005b7a4cd6%hidden_at%005b7a4cd6)kintel.net(005b7a4cd6%hidden_end%005b7a4cd6)>
- To: (005b7a4cd6%hidden_head%005b7a4cd6)cgal-discuss(005b7a4cd6%hidden_at%005b7a4cd6)lists-sop.inria.fr(005b7a4cd6%hidden_end%005b7a4cd6)
- Subject: Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3
- Date: Tue, 29 May 2012 09:54:50 +0200
On May 29, 2012, at 09:04 AM, Sebastien Loriot (GeometryFactory) wrote:
> Note that there should be a -frounding-math in the compilation line.
I think you may have hit the core of this issue.
Somehow, I suspect that -frounding-math is not supported by llvm-gcc, or
perhaps just Apple's version?
Is there a way I can quickly determine if this compiler simply cannot be used
with CGAL because of this?
The annoying thing is that Apple gives us only two choices at the moment:
llvm-gcc-4.2.1 or clang 3.1
-Marius
- [cgal-discuss] Crash with Nef_polyhedron_3, James Gregson, 05/28/2012
- [cgal-discuss] Re: Crash with Nef_polyhedron_3, kintel, 05/29/2012
- Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3, Sebastien Loriot (GeometryFactory), 05/29/2012
- Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3, Marius Kintel, 05/29/2012
- Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3, Joachim Reichel, 05/29/2012
- Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3, Marius Kintel, 05/30/2012
- Re: [cgal-discuss] Re: Crash with Nef_polyhedron_3, Marc Glisse, 05/30/2012
