cgal-discuss - Re: [cgal-discuss] how to draw closed bezier curve
  • To:
  • Subject: Re: [cgal-discuss] how to draw closed bezier curve
  • Date: Thu, 31 May 2012 10:07:46 -0500
Hi,
Seeing the image I assume that you are interested in getting the triangle from
a beziers curve, right?
Well, I only find a way to make a closed curve using splines and it is
creating several curves and fusing them in their extreme points.
regards
Felipe
Ph.D. Sistemas Informáticos
On Wed, 30 May 2012 23:29:57 -0700 (PDT), cnng0315 wrote
> the class CGAL::_Bezier_curve_2 has no such method of setClosed(the first
> point and the last are the same in Gis). I want to draw closed
> bezier curves. http://cgal-
> discuss.949826.n4.nabble.com/file/n4655125/closed_bezier.jpg
> technology change life!
> View this message in context: http://cgal-
> discuss.949826.n4.nabble.com/how-to-draw-closed-bezier-curve-tp4655125.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
