cgal-discuss - Re: [cgal-discuss] Rebuild All: 1 succeeded but no output is shown
  • To:
  • Subject: Re: [cgal-discuss] Rebuild All: 1 succeeded but no output is shown
  • Date: Thu, 31 May 2012 15:43:55 +0300
Well I really appreciate all the help provided to me by this great
List. I'm newbie and I thought I can learn if i got with contact with
those who are dealing with this library. Anyways am sorry for
disturbing and will try to not ask again such questions. Thanks
On 31 May 2012 15:14, Daniel Weber
wrote:
> Hello Sweety Pie,
> you have sent a lot of questions in the last months. Many of them (if not
> all) are related to cmake, c++, visual studio, dlls, etc...  i would
> suggest that you first make yourself familiar with those topics and ask the
> related questions in other appropriate lists or forums, before you try to
> use CGAL.
> Thank you!
> Daniel
> -------- Original-Nachricht --------
>> Datum: Thu, 31 May 2012 13:18:07 +0300
>> Von: Sweety Pie
>> An:
>> Betreff: Re: [cgal-discuss] Rebuild All: 1 succeeded but no output is shown
>> Sorry, my fault, I found the .exe file but when I double click on it,
>> it just starts and in microseconds closes. I can even see what is
>> written on the screen :( any ideas why??
>> On 31 May 2012 12:29, Sweety Pie
>> wrote:
>> > Well I went to the CGAL folder located on my C: drive and found a
>> > folder called constrained.dir
>> > inside there is the Debug folder but there r no .exe files!!!
>> > Did I searched in the wrong place or what?
>> > On 31 May 2012 12:22, Sebastien Loriot (GeometryFactory)
>> > wrote:
>> >> He meant did you try running the .exe file that is created during the
>> >> compilation?
>> >> Sebastien.
>> >> On 05/31/2012 11:01 AM, Sweety Pie wrote:
>> >>> Thanks for the reply but am afraid I didn't get what do you mean by
>> >>> the created executable?? :(
>> >>> On 31 May 2012 11:27, Philipp Moeller
>> >>>  wrote:
>> >>>> Sweety
>> >>>> Pie<>
>> >>>>  writes:
>> >>>>> Dear all,
>> >>>>> Am running the code of the Constrained Delaunay triangulation
>> example
>> >>>>> provided by CGAL. After building it is shows  Rebuild All: 1
>> succeeded
>> >>>>> at the end but there is no output shown. It even doesn't lunch any
>> >>>>> additional screens or anything. Any idea why??
>> >>>>> Thanks for your help,
>> >>>> This might be obvious: Did you launch the created executable after
>> >>>> building it?
>> >>>> Cheers,
>> >>>> Philipp Moeller
>> >>>> GeometryFactory
>> >>>> You are currently subscribed to cgal-discuss.
>> >>>> To unsubscribe or access the archives, go to
>> >>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
> NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
> Jetzt informieren: http://mobile.1und1.de/?ac=OM.PW.PW003K20328T7073a
