cgal-discuss - Re: [cgal-discuss] Re: Getting the N-ring edges / vertices for a Polyhedron vertex
  • To:
  • Subject: Re: [cgal-discuss] Re: Getting the N-ring edges / vertices for a Polyhedron vertex
  • Date: Thu, 07 Jun 2012 09:07:21 +0200
Note that you might want to use the following:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/BGL/Chapter_main.html
Sebastien
On 06/07/2012 08:47 AM, Zohar wrote:
Thanks for the link, and I think the archive link in cgal.org should be
updated:
http://www.cgal.org/mailing_list.html
Regarding the solution, it's fine, although I was also wondering about the
boost breadth_first_search with a distance map version.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Getting-the-N-ring-edges-vertices-for-a-Polyhedron-vertex-tp4655166p4655168.html
