- To:
- Subject: Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed
- Date: Thu, 07 Jun 2012 10:11:12 +0200
Thanks for the feedback.
OK, I found the problem.
Variants to be selected must be:
Multithreaded debug DLL
Multithreaded DLL
Multithreaded debug
Multithreaded
Then you need to set:
BOOST_INCLUDEDIR=C:\Program Files (x86)\boost\boost_1_47
BOOST_LIBRARYDIR=C:\Program Files (x86)\boost\boost_1_47\lib
and to append to your PATH C:\Program Files (x86)\boost\boost_1_47\lib;
Then no cmake modifications are needed.
Sebastien.
On 06/06/2012 01:01 PM, Devashish Tyagi wrote:
Adding the following lines to CGAL_SetupBoost.cmake fixed my error
set(Boost_USE_STATIC_LIBS ON)
set(Boost_USE_MULTITHREADED ON)
set(Boost_ADDITIONAL_VERSIONS "1.47")
On Wed, Jun 6, 2012 at 3:39 PM, Devashish Tyagi
<mailto:>>
wrote:
I followed your tutorial and tried installing CGAL 4.0 beta1 on my
32 bit windows machine. When I ran cmake configure I encountered the
following error
CMake Error at cmake/modules/FindBoost.cmake:917 (message):
Unable to find the requested Boost libraries.
Boost version: 1.47.0
Boost include path: C:/Program Files/boost/boost_1_47
The following Boost libraries could not be found:
boost_thread
No Boost libraries were found. You may need to set Boost_LIBRARYDIR
to the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
Call Stack (most recent call first):
cmake/modules/CGAL_SetupBoost.cmake:6 (find_package)
cmake/modules/CGAL_SetupDependencies.cmake:32 (include)
CMakeLists.txt:455 (include)
On Mon, Jun 4, 2012 at 6:51 PM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
Hello CGAL users,
Due to the increasing traffic on this list about installation
issues on
Windows, we decided to come up with a dedicated tutorial.
In order to make it better, we would like people to read/try it
and send feedback (typos, what did not work, what can be
improved, ...).
You can send it to the list or directly to me if you prefer.
The current address of the page is:
http://www.cgal.org/windows___installation.html
<http://www.cgal.org/windows_installation.html>
Thanks for your help,
Sebastien.
https://lists-sop.inria.fr/__wws/info/cgal-discuss
<https://lists-sop.inria.fr/wws/info/cgal-discuss>
Devashish Tyagi
Junior Undergraduate
Computer Science and Engineering Dept.
IIT Delhi
Devashish Tyagi
IIT Delhi
- [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sebastien Loriot (GeometryFactory), 06/04/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Devashish Tyagi, 06/06/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sebastien Loriot (GeometryFactory), 06/07/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Sweety Pie, 06/09/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Philipp Moeller, 06/09/2012
- Re: Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Laurent Rineau (CGAL/GeometryFactory), 06/11/2012
- Re: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Philipp Moeller, 06/11/2012
- RE: [cgal-discuss] Tutorial to install CGAL on Windows: Feedback needed, Max, 06/09/2012
- [cgal-discuss] RE: Tutorial to install CGAL on Windows: Feedback needed, edward, 06/09/2012
