cgal-discuss - Re: [cgal-discuss] CGAL installation
  • To:
  • Subject: Re: [cgal-discuss] CGAL installation
  • Date: Fri, 15 Jun 2012 12:48:51 +0100
Hi Laurent,
Thanks a lot for your help.
When I run cmake-gui and Configure I read the following messages in the bottom part of the windows. Some tests are failed.
Build CGAL from release: CGAL-4.0
Packagenames: CGAL-4.0
CGAL_MAJOR_VERSION=4
CGAL_MINOR_VERSION=0
CGAL_BUGFIX_VERSION=0
CGAL_SONAME_VERSION=9
CGAL_SOVERSION =9.0.0
CGAL_REFERENCE_CACHE_DIR=
Building shared libraries
Targetting Xcode
Using /usr/bin/g++ compiler.
DARWIN_VERSION=11
Mac Leopard detected
Generator uses intermediate configuration directory: $(CONFIGURATION)$(EFFECTIVE_PLATFORM_NAME)
USING CMake version: 2.8.8
System: Darwin
USING GCC_VERSION = 'Not GNU/CC (CLANG)'
Build type: Release
USING CXXFLAGS = ' -O3 -DNDEBUG'
USING LDFLAGS = ' -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib '
GMP include: /usr/local/include
GMP libraries: /usr/local/lib/libgmp.dylib
GMP definitions:
USING GMP_VERSION = '5.0.5'
MPFR include: /usr/local/include
MPFR libraries: /usr/local/lib/libmpfr.dylib
MPFR definitions:
USING MPFR_VERSION = '3.1.0'
Boost include: /Applications/include
Boost libraries: /Applications/lib/libboost_thread.dylib
Boost definitions:
USING BOOST_VERSION = '1.49.0'
Performing Test CGAL_CFG_ARRAY_MEMBER_INITIALIZATION_BUG - Failed
Performing Test CGAL_CFG_DENORMALS_COMPILE_BUG - Success
Performing Test CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG - Success
Performing Test CGAL_CFG_IEEE_754_BUG - Success
Performing Test CGAL_CFG_ISTREAM_INT_BUG - Success
Performing Test CGAL_CFG_LONGNAME_BUG - Success
Performing Test CGAL_CFG_MATCHING_BUG_5 - Success
Performing Test CGAL_CFG_MATCHING_BUG_6 - Success
Performing Test CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG - Failed
Performing Test CGAL_CFG_NO_CPP0X_ARRAY - Failed
Performing Test CGAL_CFG_NO_CPP0X_AUTO - Success
Performing Test CGAL_CFG_NO_CPP0X_COPY_N - Failed
Performing Test CGAL_CFG_NO_CPP0X_DECLTYPE - Failed
Performing Test CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES - Success
Performing Test CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS - Failed
Performing Test CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS - Success
Performing Test CGAL_CFG_NO_CPP0X_INITIALIZER_LISTS - Failed
Performing Test CGAL_CFG_NO_CPP0X_ISFINITE - Success
Performing Test CGAL_CFG_NO_CPP0X_LAMBDAS - Failed
Performing Test CGAL_CFG_NO_CPP0X_LONG_LONG - Success
Performing Test CGAL_CFG_NO_CPP0X_NEXT_PREV - Failed
Performing Test CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE - Failed
Performing Test CGAL_CFG_NO_CPP0X_STATIC_ASSERT - Failed
Performing Test CGAL_CFG_NO_CPP0X_TUPLE - Failed
Performing Test CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES - Success
Performing Test CGAL_CFG_NO_LIMITS - Success
Performing Test CGAL_CFG_NO_LOGICAL_OPERATORS_ALTERNATIVES - Success
Performing Test CGAL_CFG_NO_MESSAGE_PRAGMA_BUG - Success
Performing Test CGAL_CFG_NO_NEXTAFTER - Success
Performing Test CGAL_CFG_NO_STATEMENT_EXPRESSIONS - Success
Performing Test CGAL_CFG_NO_STL - Success
Performing Test CGAL_CFG_NO_TMPL_IN_TMPL_PARAM - Success
Performing Test CGAL_CFG_NO_TR1_ARRAY - Success
Performing Test CGAL_CFG_NO_TR1_TUPLE - Success
Performing Test CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG - Success
Performing Test CGAL_CFG_NUMERIC_LIMITS_BUG - Success
Performing Test CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG - Success
Performing Test CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG - Success
Performing Test CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG - Success
Performing Test CGAL_CFG_USING_BASE_MEMBER_BUG_2 - Success
Library config detected: Core
Library config detected: ImageIO
OpenGL include: /System/Library/Frameworks/OpenGL.framework
OpenGL libraries: /System/Library/Frameworks/AGL.framework;/System/Library/Frameworks/OpenGL.framework
USING ZLIB_VERSION = '1.2.5'
ZLib include: /usr/include
ZLib libraries: /usr/lib/libz.dylib
Library config detected: Qt3
Library config detected: Qt4
Library configs detected: CGAL;Core;ImageIO;Qt3;Qt4
Configuring done
2012/6/15 Laurent Rineau (CGAL/GeometryFactory) <>
Le vendredi 15 juin 2012 11:35:32 christelle yeromonahos a écrit :
> Hi,
> I am new to CGAL, and I am trying to install it on Mac OSX. Could you
> please help me?
> I have configured CGAL with
> cd CGAL-4.0
> cmake-gui .
> Now I would like to build libraries thanks to
> (cd CGAL-4.0)
> make
> But I get the error: make: ***No targets specified and no makefile found.
> Stop.
Relaunch cmake-gui, click Configure, and read the messages in the bottom part
of the Windows. Probably you are missing important dependencies, and CMake was
not able to properly configure CGAL libraries.
Or use precompiled libraries from a distribution, like macport.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
