cgal-discuss - Re: Re: [cgal-discuss] CGAL installation
  • To:
  • Subject: Re: Re: [cgal-discuss] CGAL installation
  • Date: Fri, 15 Jun 2012 14:19:53 +0200
Le vendredi 15 juin 2012 12:48:51 christelle yeromonahos a écrit :
> Hi Laurent,
> Thanks a lot for your help.
> When I run cmake-gui and Configure I read the following messages in the
> bottom part of the windows. Some tests are failed.
Some tests or feature detections can fail without compromising the
compilation
of CGAL libraries. It only defines several workaround macros in
<CGAL/compiler_config.h>.
> Build CGAL from release: CGAL-4.0
> Packagenames: CGAL-4.0
> CGAL_MAJOR_VERSION=4
> CGAL_MINOR_VERSION=0
> CGAL_BUGFIX_VERSION=0
> CGAL_SONAME_VERSION=9
> CGAL_SOVERSION =9.0.0
> CGAL_REFERENCE_CACHE_DIR=
> Building shared libraries
> Targetting Xcode
> Using /usr/bin/g++ compiler.
> DARWIN_VERSION=11
> Mac Leopard detected
> Generator uses intermediate configuration directory:
> $(CONFIGURATION)$(EFFECTIVE_PLATFORM_NAME)
> USING CMake version: 2.8.8
> System: Darwin
> USING GCC_VERSION = 'Not GNU/CC (CLANG)'
When you first ran CMake configuration in that build directory, cmake-gui
popped up a dialog asking you to choose a "generator". You have chosen the
default choice, and that was "Xcode". With that generator, CMake does not
create a set of makefiles but an Xcode project file.
You can either:
- clean the cache and restart, choosing "Unix Makefile" as generator,
- or compile CGAL libraries using Xcode.
Be warned that the clang compiler is not supported by the CGAL project.
Laurent Rineau, PhD
