- To:
- Subject: Re: [cgal-discuss] Get all neighboring vertices in Delaunay_d?
- Date: Fri, 22 Jun 2012 14:29:21 +0200
On 06/22/2012 06:41 AM, Ronaldo Carpio wrote:
Hi,The only way I see to do it is to iterator over simplices, select those
Is there a way to get all neighboring vertices of a given vertex in
Delaunay_d?
of dimension 1 and get the connections between vertices (you'll get it
for all vertices).
Sebastien.
Thanks,
Ronaldo Carpio
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Get-all-neighboring-vertices-in-Delaunay-d-tp4655297.html
- [cgal-discuss] Get all neighboring vertices in Delaunay_d?, Ronaldo Carpio, 06/22/2012
- Re: [cgal-discuss] Get all neighboring vertices in Delaunay_d?, Sebastien Loriot (GeometryFactory), 06/22/2012
