cgal-discuss - Re: [cgal-discuss] Surface_reconstruction_points_3, macports, eigen problem
  • To:
  • Subject: Re: [cgal-discuss] Surface_reconstruction_points_3, macports, eigen problem
  • Date: Fri, 22 Jun 2012 14:59:35 +0200
Well, I compiled the example using the alpha version of eigen and obtained an
executable (i.e. no compilation errors were generated). Then I tried to run
it and go the "Segmentation fault".
Let me know what further details can I provide?
All the best,
Dror
On Jun 21, 2012, at 08:01 AM, Sebastien Loriot (GeometryFactory) wrote:
> On 06/20/2012 06:55 PM, Dror Atariah wrote:
>> This indeed solved the problem, and compilation managed to be completed!
>> However, trying to run the resulting executable yielded: "Segmentation
>> fault"
>> I guess this means that this is a new problem, so should I send a new
>> email?
> Indeed, it would be nice if you explain what you did to see if we can
> reproduce the problem.
> thanks,
> Sebastien.
>> Thanks a lot for the quick answers!
>> On Jun 20, 2012, at 17:43 PM, Sebastien Loriot (GeometryFactory) wrote:
>>> There is indeed a compatibility problem of CGAL with the version
>>> 3.1.0-rc1 of Eigen. We'll fix that.
>>> In the meantime, can you use Eigen 3.1.0-alpha1 which I know is working.
>>> Sorry for the inconvenience.
>>> Sebastien.
>>> On 06/20/2012 05:27 PM, Dror Atariah wrote:
>>>> I cleared all the previously generated Cmake related files. Then I ran
>>>> the cgal_create_cmake_script and then what you suggested:
>>>>> "cmake -DEIGEN3_INCLUDE_DIR=/Users/drorata/Library/eigen3.1.0-rc1 ."
>>>> This was the output:
>>>> ---(Output)---
>>>> -- The C compiler identification is GNU 4.2.1
>>>> -- The CXX compiler identification is GNU 4.2.1
>>>> -- Checking whether C compiler has -isysroot
>>>> -- Checking whether C compiler has -isysroot - yes
>>>> -- Checking whether C compiler supports OSX deployment target flag
>>>> -- Checking whether C compiler supports OSX deployment target flag - yes
>>>> -- Check for working C compiler: /usr/bin/gcc
>>>> -- Check for working C compiler: /usr/bin/gcc -- works
>>>> -- Detecting C compiler ABI info
>>>> -- Detecting C compiler ABI info - done
>>>> -- Checking whether CXX compiler has -isysroot
>>>> -- Checking whether CXX compiler has -isysroot - yes
>>>> -- Checking whether CXX compiler supports OSX deployment target flag
>>>> -- Checking whether CXX compiler supports OSX deployment target flag -
>>>> yes
>>>> -- Check for working CXX compiler: /usr/bin/c++
>>>> -- Check for working CXX compiler: /usr/bin/c++ -- works
>>>> -- Detecting CXX compiler ABI info
>>>> -- Detecting CXX compiler ABI info - done
>>>> -- Build type: Release
>>>> -- USING CXXFLAGS = '-pipe -O2 -arch x86_64 -frounding-math
>>>> -fno-strict-aliasing -O3 -DNDEBUG'
>>>> -- USING EXEFLAGS = ' -L/opt/local/lib -arch x86_64
>>>> -Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
>>>> -- Targetting Unix Makefiles
>>>> -- Using /usr/bin/c++ compiler.
>>>> -- DARWIN_VERSION=10
>>>> -- Mac Leopard detected
>>>> -- Configuring done
>>>> -- Generating done
>>>> CMake Warning:
>>>> Manually-specified variables were not used by the project:
>>>> EIGEN3_INCLUDE_DIR
>>>> -- Build files have been written to:
>>>> /Users/drorata/Documents/academics/programing/CGAL/Surface_reconstruction_points_3_CGAL_4
>>>> ---(Output END)---
>>>> Then trying to compile the example yielded:
>>>> ---(Output)---
>>>> In file included from
>>>> /opt/local/include/CGAL/Poisson_reconstruction_function.h:32,
>>>> from
>>>> /Users/drorata/Documents/academics/programing/CGAL/Surface_reconstruction_points_3_CGAL_4/poisson_reconstruction_example.cpp:10:
>>>> /opt/local/include/CGAL/Eigen_solver_traits.h:24:24: error:
>>>> Eigen/Sparse: No such file or directory
>>>> In file included from /opt/local/include/CGAL/Eigen_solver_traits.h:26,
>>>> from
>>>> from
>>>> /opt/local/include/CGAL/Eigen_vector.h:24:22: error: Eigen/Core: No such
>>>> file or directory
>>>> ...(CONTINUES)
>>>> ---(Output END)---
>>>> This seems not to work.
>>>> I don't think that the problem is finding EIGEN. Currently I have (as
>>>> Michael Hemmer suggested) the following line in my CMakeLists.txt:
>>>> include_directories (BEFORE "~/Library/eigen3.1.0-rc1/")
>>>> It seems like neither your suggestion nor setting EIGEN3_INC_DIR to the
>>>> eigen's location helps.
>>>> Anyway, with either Michael's trick or Menelaos' (which was adding a
>>>> soft link to the include directory of the example which pointed to the
>>>> location of eigen) it seems like eigen can be found, but the compilation
>>>> error is always there.
>>>> Dror.
>>>> On Jun 20, 2012, at 16:55 PM, Sebastien Loriot (GeometryFactory) wrote:
>>>>> Try:
>>>>> There should be no need to do something else for the demo.
>>>>> This was documented on that page:
>>>>> http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Subsection_10.4
>>>>> Sebastien.
>>>>> On 06/20/2012 04:19 PM,
>>>>> wrote:
>>>>>> I have installed *CGAL 4.0* on a Mac OS 10.6 using *macports*. As a
>>>>>> test
>>>>>> case, I tried to compile the example given in /Triangulation_2/, using
>>>>>> the
>>>>>> standard procedure:
>>>>>> - cgal_create_cmake_script
>>>>>> - cmake .
>>>>>> - make
>>>>>> This worked like a charm and suggests, if I understand it correctly,
>>>>>> that
>>>>>> CGAL's installation is OK.
>>>>>> Next, I wanted to compile and consider the example
>>>>>> /Surface_reconstruction_points_3/. Here things got messy. I'll try to
>>>>>> describe the steps I took (some of them with the great help of Menelaos
>>>>>> Karavelas and Michael Hemmer. Thank you Menelaos and MIchael) in order
>>>>>> to
>>>>>> resolve the issue.
>>>>>> The version of Eigen shipped with the CGAL installation through
>>>>>> macports is
>>>>>> old, and thus I downloaded manually the latest version of eigen
>>>>>> (3.1.0-rc1).
>>>>>> In addition, I added the following line to the CMakeLists.txt:
>>>>>> where ~/Library/eigen3.1.0-rc1/ is where the file
>>>>>> "signature_of_eigen3_matrix_library" is located.
>>>>>> This should make sure that eigen will be looked for in the right
>>>>>> location.
>>>>>> Then I added
>>>>>> #define CGAL_EIGEN3_ENABLED
>>>>>> to the example "poisson_reconstruction_example.cpp". Finally, I ran:
>>>>>> - cmake .
>>>>>> - make poisson_reconstruction_example
>>>>>> Then I got the following compilation error:
>>>>>> ---Compilation Error Cite---
>>>>>> /Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/Core/util/Meta.h: In
>>>>>> copy
>>>>>> constructor
>>>>>> ‘Eigen::IterativeSolverBase<Eigen::ConjugateGradient<Eigen::SparseMatrix<double,
>>>>>> 0, int>, 1, Eigen::DiagonalPreconditioner<double> >
>>>>>>> ::IterativeSolverBase(const
>>>>>> 0, int>, 1, Eigen::DiagonalPreconditioner<double> > >&)’:
>>>>>> /Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/IterativeLinearSolvers/
>>>>>> IterativeSolverBase.h:37: instantiated from ‘bool
>>>>>> CGAL::Poisson_reconstruction_function<Gt>::compute_implicit_function()
>>>>>> [with
>>>>>> Gt = CGAL::Epick]’
>>>>>> Surface_reconstruction_points_3_CGAL_4/poisson_reconstruction_example.cpp:65:
>>>>>> instantiated from here
>>>>>> /Users/drorata/Library/eigen3.1.0-rc1/Eigen/src/Core/util/Meta.h:113:
>>>>>> error:
>>>>>> ‘Eigen::internal::noncopyable::noncopyable(const
>>>>>> Eigen::internal::noncopyable&)’ is private
>>>>>> IterativeSolverBase.h:37: error: within this context
>>>>>> ConjugateGradient.h: In copy constructor
>>>>>> ‘Eigen::ConjugateGradient<Eigen::SparseMatrix<double, 0, int>, 1,
>>>>>> Eigen::DiagonalPreconditioner<double> >::ConjugateGradient(const
>>>>>> Eigen::DiagonalPreconditioner<double> >&)’:
>>>>>> ConjugateGradient.h:160: instantiated from ‘bool
>>>>>> [with
>>>>>> Gt = CGAL::Epick]’
>>>>>> ConjugateGradient.h:160: note: synthesized method
>>>>>> 0, int>, 1, Eigen::DiagonalPreconditioner<double> > >&)’ first
>>>>>> required here
>>>>>> /opt/local/include/CGAL/Eigen_solver_traits.h: In copy constructor
>>>>>> ‘CGAL::Eigen_solver_traits<Eigen::ConjugateGradient<Eigen::SparseMatrix<double,
>>>>>>> ::Eigen_solver_traits(const
>>>>>> /opt/local/include/CGAL/Eigen_solver_traits.h:58: instantiated from
>>>>>> ‘bool
>>>>>> [with
>>>>>> Gt = CGAL::Epick]’
>>>>>> /opt/local/include/CGAL/Eigen_solver_traits.h:58: note: synthesized
>>>>>> method
>>>>>> Eigen::DiagonalPreconditioner<double> >&)’ first required here
>>>>>> /opt/local/include/CGAL/Poisson_reconstruction_function.h: In member
>>>>>> function
>>>>>> ‘bool
>>>>>> [with Gt = CGAL::Epick]’:
>>>>>> /opt/local/include/CGAL/Poisson_reconstruction_function.h:264: note:
>>>>>> synthesized method
>>>>>> required here
>>>>>> make[3]: *** [CMakeFiles/poisson_reconstruction_example.dir/
>>>>>> poisson_reconstruction_example.cpp.o] Error 1
>>>>>> make[2]: *** [CMakeFiles/poisson_reconstruction_example.dir/all] Error
>>>>>> 2
>>>>>> make[1]: *** [CMakeFiles/poisson_reconstruction_example.dir/rule]
>>>>>> Error 2
>>>>>> make: *** [poisson_reconstruction_example] Error 2
>>>>>> ---Compilation Error END---
>>>>>> I am unable to find what the problem is? Seems like it is either a
>>>>>> problem in
>>>>>> EIGEN, or the way it is being using in CGAL/this specific example.
>>>>>> If further details regarding my setting etc. is needed please let me
>>>>>> know.
>>>>>> Thanks in advance!
>>>>>> Dror Atariah
>>>>>> PS: I'm in Chapel Hill till tomorrow, so if you're around I'm
>>>>>> available to
>>>>>> have a look at the problem together.
>>>>> You are currently subscribed to cgal-discuss.
>>>>> To unsubscribe or access the archives, go to
>>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
