- To:
- Subject: Re: [cgal-discuss] Intersections with a Nef_polyhedron_3
- Date: Mon, 02 Jul 2012 17:37:13 +0200
Le 29/06/2012 16:12, Sebastien Loriot (GeometryFactory) a écrit :
If I want to test the intersection with a >=2-dimension primitive, I
think a good way is to build a Polyhedron_3 from that primitive and
substract it from the Nef_polyhedron.
But what about points and lines ?
You should use this [1] package for that purpose.
The idea is to reduce intersection test at the face level.
(Note that you can use a polyhedron instead of a nef-polyhedron).
You can also test the intersection between two polyhedra with this package.
Thank you for your answer.
How is it related to AABB trees ?
I am currently using them to speed up intersection tests. I understand that "Box_intersection_d" are more general than AABB trees (especially in the bipartite case), but how do they behave, for instance, on the case of a 1-triangle-N-segments intersection test where do_intersect( triangle ) is called on an AABB tree built from a set of Segment_3 ?
About points, there is a locate( Point_3 ) method, but I cannot figure
out how to know if the resulting volume is the bounded one (my
nef_polyhedron) or the unbounded "outter" volume (A similar question has
been asked some time ago on this list without answer).
If you constructed a nef polyhedron, if you call mark() member function
of the volume, true means its in the model.
Thanks, it works fine.
Hugo Mercier
Oslandia
- Re: [cgal-discuss] Intersections with a Nef_polyhedron_3, Hugo Mercier, 07/02/2012
- Re: Re: [cgal-discuss] Intersections with a Nef_polyhedron_3, Laurent Rineau (CGAL/GeometryFactory), 07/02/2012
