- To:
- Subject: Re: Re: [cgal-discuss] Intersections with a Nef_polyhedron_3
- Date: Mon, 02 Jul 2012 17:59:45 +0200
Le lundi 02 juillet 2012 17:37:13 Hugo Mercier a écrit :
> Le 29/06/2012 16:12, Sebastien Loriot (GeometryFactory) a écrit :
> >> If I want to test the intersection with a >=2-dimension primitive, I
> >> think a good way is to build a Polyhedron_3 from that primitive and
> >> substract it from the Nef_polyhedron.
> >> But what about points and lines ?
> > You should use this [1] package for that purpose.
> > The idea is to reduce intersection test at the face level.
> > (Note that you can use a polyhedron instead of a nef-polyhedron).
> > You can also test the intersection between two polyhedra with this
> > package.
> Thank you for your answer.
> How is it related to AABB trees ?
> I am currently using them to speed up intersection tests. I understand
> that "Box_intersection_d" are more general than AABB trees (especially
> in the bipartite case), but how do they behave, for instance, on the
> case of a 1-triangle-N-segments intersection test where do_intersect(
> triangle ) is called on an AABB tree built from a set of Segment_3 ?
"AABB Tree" and the "Bbox_intersection_d" are different packages, with
different approaches.
"AABB Tree" is for intersections tests when you have a big object that is
fixed, and a set of intersections queries between the big object and small
query objects. the AABB Tree stores a hierarchy of bounding boxes for the big
object.
The "Bbox intersection" package is for one-shot intersections queries for
- self-intersection of a big object,
- or for intersections of two big objects.
No data structure is kept in memory between two different calls to functions
of that package.
Laurent Rineau, PhD
- Re: [cgal-discuss] Intersections with a Nef_polyhedron_3, Hugo Mercier, 07/02/2012
- Re: Re: [cgal-discuss] Intersections with a Nef_polyhedron_3, Laurent Rineau (CGAL/GeometryFactory), 07/02/2012
