cgal-discuss - [cgal-discuss] Working kernels for make_conforming_*_2 and refine_Delaynay_mesh_2 ??
  • To:
  • Subject: [cgal-discuss] Working kernels for make_conforming_*_2 and refine_Delaynay_mesh_2 ??
  • Date: Wed, 4 Jul 2012 07:40:49 -0700 (PDT)
Hello guys,
I'm trying to call the mentioned functions with various kernels (in the
constrained Delaunays), but I get the
"Converting from 'CGAL::Null_functor::result_type' to 'const [various]' not
possible"-error quite often.
I'm just using the example code given in the manual (46.1.3 for conforming,
46.2.5 for refine Delaunay).
The Kernels I'm testing are Cartesians and SimpleCartesian for the number
types double, CORE::Expr, Quotient<MPFloat>, Gmpq, mpqclass, leda::rational
and leda::real.
Double, Core and leda::real are compiling, the others don't. I already
learned from other threads, that EPEC doesn't work, which could imply that
Gmpq und Quotient<MPFloat> do not work as well, but I don't understand why.
Am I doing it wrong, maybe I miss something when using the not working
kernels? Or is it simply not possible to use them for the given functions
due to a certain reason? Will it be the same, when I'm experimenting with
similar problems, like Surface Mesh Simplifikation?
Thanks in advance
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Working-kernels-for-make-conforming-2-and-refine-Delaynay-mesh-2-tp4655362.html
