Re: [cgal-discuss] Re: Working kernels for make_conforming_*_2 and refine_Delaynay_mesh_2 ??
- To:
- Subject: Re: [cgal-discuss] Re: Working kernels for make_conforming_*_2 and refine_Delaynay_mesh_2 ??
- Date: Fri, 06 Jul 2012 08:21:07 +0200
On 07/05/2012 03:01 PM, CaulDrohn wrote:
Thanks for answering so fastSqrt_extension has a limited subset of operations.
I would like to ask an aditional question:
Is it possible to extend the number types in a way that they allow the sqrt?
I found CGAL::Sqrt_extension and thought i could give it a try, but got the
same error.
I was trying:
typedef CGAL::Sqrt_extension<CGAL::Gmpq,CGAL::Gmpq> GmpqSqrt;
typedef CGAL::Cartesian<GmpqSqrt> K;
In particular, many binary operations expect that the extension is identical.
See the documentation for more details:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/NumberTypeSupport_ref/Class_Sqrt_extension.html
Sebastien.
Either I'm doing it wrong or Sqrt_extension doesn't work as I'm naively
thinking.
Thanks in advance (again )
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Working-kernels-for-make-conforming-2-and-refine-Delaynay-mesh-2-tp4655362p4655376.html
- [cgal-discuss] Working kernels for make_conforming_*_2 and refine_Delaynay_mesh_2 ??, CaulDrohn, 07/04/2012
- Re: [cgal-discuss] Working kernels for make_conforming_*_2 and refine_Delaynay_mesh_2 ??, Laurent Rineau (CGAL/GeometryFactory), 07/04/2012
- [cgal-discuss] Re: Working kernels for make_conforming_*_2 and refine_Delaynay_mesh_2 ??, CaulDrohn, 07/05/2012
- Re: [cgal-discuss] Re: Working kernels for make_conforming_*_2 and refine_Delaynay_mesh_2 ??, Sebastien Loriot (GeometryFactory), 07/06/2012
- Re: [cgal-discuss] Re: Working kernels for make_conforming_*_2 and refine_Delaynay_mesh_2 ??, Laurent Rineau (CGAL/GeometryFactory), 07/10/2012
