cgal-discuss - Re: [cgal-discuss] CGAL build with Eigen
  • To:
  • Subject: Re: [cgal-discuss] CGAL build with Eigen
  • Date: Fri, 13 Jul 2012 11:38:43 +0200
On 07/13/2012 11:34 AM, mriem wrote:
Hi
I am trying to compile CGAL 4.02 which I downloaded from
https://gforge.inria.fr/frs/?group_id=52
I want to use surface meshing algorithms which, I read somewhere, require
the TAUCS lib.
When I looked into the installation manual for CGAL at
http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Subsection_10.4
it says "The usage of Eigen allows to remove lapack, blas and Taucs from the
list of third party libraries required by some Cgal packages. Note that the
version 3.1 (or greater) of Eigen is required."
So I downloaded and installed EIGEN, then I stated to build cgal
cmake (this part puzzles me since there is no mention to EIGEN or TAUCS)
make
make install
It installs until the end, no problem.
My problem is when I try to compile code from CGAL example that does surface
reconstruction from point sets
Everything should be set automatically in CGAL's example.
You simply have to provide to cmake the path to the Eigen directory
(cmake -DEIGEN3_INCLUDE_DIR=/path/to/directory/containing/signature_of_eigen3_matrix_library .)
Could you provide the cmake output when you configured the demo?
Sebastien.
