- To:
- Subject: [cgal-discuss] Re: CGAL build with Eigen
- Date: Fri, 13 Jul 2012 03:39:34 -0700 (PDT)
Hi Sebastien
I did what you said
#Added this before to find eigen, directory where FindEigen3.cmake is
set(CMAKE_MODULE_PATH "~/Installed_apps/eigen-eigen-ca142d0540d3/cmake")
#Sebastiens instructions
find_package(Eigen3 3.0.91)
if(EIGEN3_FOUND)
include( ${EIGEN3_USE_FILE} ) #this is where the error occurs!
else()
message(STATUS "NOTICE: Eigen library is not found.")
endif()
But I get and error when doing make
include called with wrong number of arguments. Include only takes one file.
Any idea why this happens?
Thanks
Miguel
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-build-with-Eigen-tp4655443p4655447.html
- [cgal-discuss] CGAL build with Eigen, mriem, 07/13/2012
- Re: [cgal-discuss] CGAL build with Eigen, Sebastien Loriot (GeometryFactory), 07/13/2012
- [cgal-discuss] Re: CGAL build with Eigen, mriem, 07/13/2012
- Re: [cgal-discuss] Re: CGAL build with Eigen, Sebastien Loriot (GeometryFactory), 07/13/2012
