- To:
- Subject: Re: [cgal-discuss] How to get Contour of the intersection plane and polyhedron
- Date: Tue, 17 Jul 2012 08:50:36 +0800
Hello Sebastien Loriot,
Thank you replay.
Yes, I test the example of AABB tree demo. There is no problem to caculate intersections between a plane and polyhedron.
But, the results of intersections are many Segment object. I debug those segments, and find that those intersetion segments is no end to end Sequentially.
I want to find loops (segment attach together sequentially).
My question:How to constitute "Loops" using those segments??
2012/7/13 Sebastien Loriot (GeometryFactory) <>
If you run the AABB_tree demo, you can open an off file (simple to
create from stl), then
run Algorithms ->cut plane -> intersection.
You can extract the code from the demo (file Scene.cpp function
cut_segment_plane).
The principal is simple: you create an aabb_tree using the facets of the
mesh, and you
create all intersections with you plane.
See:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree_ref/Class_AABB_tree.html
Sebastien.
> Email: <mailto:>
On 07/13/2012 03:29 AM, 马良 wrote:
> Hi
> I read a STL-file (a kind of file using in RapidPrototyping, a triangle
> in STL is composed of 3-Point and normal). And I create a Polyhedron
> like a following.
> Polyhedron P;
> P.make_triangle(V1,V2,V3);
> P.make_triangle(V4,V5,V6);
> //Then, I create AABB tree, as follows:
> Facet_tree tree(P.facets_begin(),P.facets_end());
> //Next, I create a plane and caculate intersections between plane and
> polyhedron
> Vector nor(0,0,1);
> Point pnt(0,0,0.5);
> Plane plane(pnt,nor);
> tree.all_intersections(plane,std::back_inserter(Intersetions));
> //Here, I get intersetions (Points: (X,Y,Z))
> for( it = Intersetions.begin();it !=Intersections.end();it++)
> if(CGAL::assign(segment,object) m_segment.push_back(segment);
> // But, I get a lot of segments. And Here I want get contours (a contour
> is composed of segments in order).
> My question is How to constitute contours using segments. Whether or not
> I must sort those segments by myself? Here is a algorithm in CGAL?
> Thanks!
> 马良 Mr.MaLiang
> State Key Laboratory of Solidification Processing
> Northwestern Polytechnical University
> Xi'an 710072, Shanxi
> P. R. China
> Tel/Fax:+86(29)88460520
> Mobile:+86(0)15829297776
> QQ number:394646034
马良 Mr.MaLiang
P. R. China
P. R. China
- [cgal-discuss] How to get Contour of the intersection plane and polyhedron, 马良, 07/13/2012
- Re: [cgal-discuss] How to get Contour of the intersection plane and polyhedron, Sebastien Loriot (GeometryFactory), 07/13/2012
- Re: [cgal-discuss] How to get Contour of the intersection plane and polyhedron, 马良, 07/17/2012
- Re: [cgal-discuss] How to get Contour of the intersection plane and polyhedron, Sebastien Loriot (GeometryFactory), 07/17/2012
