- To:
- Subject: [cgal-discuss] How to get Contour of the intersection plane and polyhedron
- Date: Fri, 13 Jul 2012 09:29:59 +0800
Hi
I read a STL-file (a kind of file using in RapidPrototyping, a triangle in STL is composed of 3-Point and normal). And I create a Polyhedron like a following.
Polyhedron P;
P.make_triangle(V1,V2,V3);
P.make_triangle(V4,V5,V6);
//Then, I create AABB tree, as follows:
Facet_tree tree(P.facets_begin(),P.facets_end());
//Next, I create a plane and caculate intersections between plane and polyhedron
Vector nor(0,0,1);
Point pnt(0,0,0.5);
Plane plane(pnt,nor);
tree.all_intersections(plane,std::back_inserter(Intersetions));
//Here, I get intersetions (Points: (X,Y,Z))
for( it = Intersetions.begin();it !=Intersections.end();it++)
if(CGAL::assign(segment,object) m_segment.push_back(segment);
// But, I get a lot of segments. And Here I want get contours (a contour is composed of segments in order).
My question is How to constitute contours using segments. Whether or not I must sort those segments by myself? Here is a algorithm in CGAL?
Thanks!
马良 Mr.MaLiang
State Key Laboratory of Solidification Processing
Northwestern Polytechnical University
Xi'an 710072, Shanxi
P. R. China
Tel/Fax:+86(29)88460520
P. R. China
- [cgal-discuss] How to get Contour of the intersection plane and polyhedron, 马良, 07/13/2012
- Re: [cgal-discuss] How to get Contour of the intersection plane and polyhedron, Sebastien Loriot (GeometryFactory), 07/13/2012
- Re: [cgal-discuss] How to get Contour of the intersection plane and polyhedron, 马良, 07/17/2012
- Re: [cgal-discuss] How to get Contour of the intersection plane and polyhedron, Sebastien Loriot (GeometryFactory), 07/17/2012
