cgal-discuss - [cgal-discuss] How to connect Segments into Loop?
  • To:
  • Subject: [cgal-discuss] How to connect Segments into Loop?
  • Date: Wed, 18 Jul 2012 14:29:58 +0800
Hello,
        I get many segments by intersecting a plane and polyhedron. But I find those segments(start point:Point(x1,y1), end point: Point(x2,y2)) are not end to end. I want get a loop (That means adjacent two segments must share a same Vertex. That is to say previour segment's end point is current segment's start point, and current segment's end point is next segment's start point, And so. )
        How can I arrangement those segments?
        I think, firstly, I get a vertex of segment, then find a same vertex in remaining segments. Then find next.
        there have easy way to do this in CGAL?
        My source:
//1.
 typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
 //Facet
 typedef CGAL::AABB_polyhedron_triangle_primitive<Kernel,Polyhedron> Facet_Primitive;
 typedef CGAL::AABB_traits<Kernel,Facet_Primitive>     Facet_Traits;
 typedef CGAL::AABB_tree<Facet_Traits>        Facet_tree;
 typedef Facet_tree::Object_and_primitive_id Object_and_primitive_id;
 typedef Kernel::FT FT;
 typedef Kernel::Point_3 Point;
 typedef Kernel::Plane_3 Plane;
 typedef Kernel::Vector_3 Vector;
 typedef Kernel::Segment_3 Segment;
 //2.
 Point V1(0.0,0.0,0.0);
 Point V2(1.0,0.0,0.0);
 Point V3(1.0,1.0,0.0);
 Point V4(0.0,1.0,0.0);
 Point V5(0.0,0.0,1.0);
 Point V6(1.0,0.0,1.0);
 Point V7(1.0,1.0,1.0);
 Point V8(0.0,1.0,1.0);
 //3.
 Polyhedron P;
 P.make_triangle(V1,V6,V5);
 P.make_triangle(V1,V2,V6);
 P.make_triangle(V2,V7,V6);
 P.make_triangle(V2,V3,V7);
 P.make_triangle(V3,V8,V7);
 P.make_triangle(V3,V4,V8);
 P.make_triangle(V4,V5,V8);
 P.make_triangle(V4,V1,V5);
 P.make_triangle(V5,V6,V7);
 P.make_triangle(V5,V7,V8);
 P.make_triangle(V1,V3,V2);
 P.make_triangle(V1,V4,V3);
//4.
 Vector nor((FT)0.0,(FT)0.0,(FT)1.0);
 Point pnt((FT)0.0,(FT)0.0,0.5);
 Plane plane(pnt,nor);
//5.1. AABB tree
 Facet_tree tree(P.facets_begin(),P.facets_end());
 //5.2. get intersections a plane and polyhedron
 std::list<Object_and_primitive_id> Intersections;
 tree.all_intersections(plane,std::back_inserter(Intersections));
 std::list<Object_and_primitive_id>::iterator it;
 std::list<Segment> m_segment;
 for(it = Intersections.begin();it!=Intersections.end();it++)
  Object_and_primitive_id op = *it;
  CGAL::Object object = op.first;
  Segment segment;
  if(CGAL::assign(segment,object)) m_segment.push_back(segment);
Note:
    Here, I get intersection segments. But those segment is not link Sequentially.
    How to connect those segments into loop???
Thanks
Ma Liang
马良  Mr.MaLiang
State Key Laboratory of Solidification Processing
Northwestern Polytechnical University
Xi'an 710072, Shanxi
P. R. China
Tel/Fax:+86(29)88460520
Mobile:+86(0)15829297776
Email:
QQ number:394646034
