- To:
- Subject: Re: [cgal-discuss] Re: ployhedron_3 dont run because qt plugin is not valid
- Date: Tue, 24 Jul 2012 14:36:50 +0200
Le jeudi 19 juillet 2012 22:08:45 Zohar a écrit :
> Make sure the the dlls in the path are from the qt bin that you compiled the
> plugins with (the could be similar dlls at other applications directories
> in the path). Use the 'which' command, which you can download from cygwin
> for example.
Alternatively, you can use the tool depends.exe, that is shipped with MSVC.
Laurent Rineau, PhD
- [cgal-discuss] ployhedron_3 dont run because qt plugin is not valid, Ephemera, 07/17/2012
- [cgal-discuss] Re: ployhedron_3 dont run because qt plugin is not valid, Zohar, 07/20/2012
- Re: [cgal-discuss] Re: ployhedron_3 dont run because qt plugin is not valid, Laurent Rineau (CGAL/GeometryFactory), 07/24/2012
