- To:
- Subject: Re: [cgal-discuss] Beginner: List of Points (3D) -> Alpha Shape -> PLY
- Date: Mon, 23 Jul 2012 10:02:01 +0200
Hej Mike,
I have some (extremely rough) PLY-stuff floating around on my HD somewhere,
that may get you started. If you're interested, you can contact me off-list.
Sincerely,
Jakob
On 07/21/2012 07:40 PM, Michael Hull wrote:
HI Felipe,
Thanks for those links. I am trying to get the cgal-python bindings at the
moment; which would make output to ply much easier.
I am still a little unclear about the difference between a triangulation and
a surface, but I will keep looking through the documentation.
Best regards
Mike
On 20 July 2012 10:25, Felipe de Jesus Trujillo Romero
<mailto:>>
wrote:
hello Mike,
in relation to the writer to PLY, I don't know if there is an
implementation on CGAL (I don't think so) but you can take a look to the
libply:
http://people.cs.kuleuven.be/~ares.lagae/libply/
or go over the website of Stanford 3D scanning repository:
http://graphics.stanford.edu/data/3Dscanrep/
bye
Felipe
**On Fri, 20 Jul 2012 08:56:32 -0500, Michael Hull wrote*
> Hello!
> I have been reading through the CGAL documentation, and it looks like
an amazing project.
> Unfortunately; I am having some trouble getting what I want out; so
before I write some hacky code; I thought I'd ask here.
> I basically want to take a set of points, (without normals), then use
alpha shapes to find a mesh over these points (since the shame has concavities),
then convert this shape into PLY file format.
> I looked through the examples, and found something similar loading a
bunny from a set of points into an alpha shape; which gives me access to the
vertices or facets, but at this point I got
confused about what exactly a triangulation is, how it compares to a
Surface, and how I access it from my Alpha_Shape_3 object.
> If someone could shed some light on this, I'd be very grateful!
> Also, is there a writer to PLY that exists already, before I write my
own?
> Many thanks in advance, and for work on what looks like a great
package.
> Mike
> P.S. I looked at the tutorial section, and some of the links are
broken. I think for beginners 'lightweighter' overview/introductory material is
very useful, since it can be difficult to get a
feeling of how all the components fit together, especially if you are
not a C++ template guru :)
- [cgal-discuss] Beginner: List of Points (3D) -> Alpha Shape -> PLY, Michael Hull, 07/20/2012
- Re: [cgal-discuss] Beginner: List of Points (3D) -> Alpha Shape -> PLY, Felipe de Jesus Trujillo Romero, 07/20/2012
- Re: [cgal-discuss] Beginner: List of Points (3D) -> Alpha Shape -> PLY, Michael Hull, 07/21/2012
- Re: [cgal-discuss] Beginner: List of Points (3D) -> Alpha Shape -> PLY, Monique Teillaud, 07/22/2012
- Re: [cgal-discuss] Beginner: List of Points (3D) -> Alpha Shape -> PLY, Jakob van Bethlehem, 07/23/2012
- Re: [cgal-discuss] Beginner: List of Points (3D) -> Alpha Shape -> PLY, Michael Hull, 07/23/2012
- Re: [cgal-discuss] Beginner: List of Points (3D) -> Alpha Shape -> PLY, Monique Teillaud, 07/23/2012
