- To:
- Subject: Re: [cgal-discuss] Static vs Shared
- Date: Mon, 23 Jul 2012 09:59:19 +0200
Hej Panagiotis,
Maybe you need to pass the '-static' option to your compiler when building
your project?
Greetsz, Jakob
On 07/20/2012 06:34 PM, Panagiotis Foteinos wrote:
Hello.
I built CGAL-4.0.2 with SHARED_LIBRARIES off. So far so good. But when
my projects links to CGAL, I get this:
No rule to make target `/usr/local/lib/libCGAL.so'
Indeed, only *.a libraries are under /usr/local/lib . Why it tries to
find shared libraries?
Any ideas?
My project is completely clean, and there is only one version (STATIC
libraries) of CGAL installed in my machine.
Regards,
Panagiotis
- [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/20/2012
- Re: [cgal-discuss] Static vs Shared, Jakob van Bethlehem, 07/23/2012
- Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/23/2012
- Re: [cgal-discuss] Static vs Shared, Sebastien Loriot (GeometryFactory), 07/25/2012
- Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/25/2012
- Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/26/2012
- Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/26/2012
- Re: Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/26/2012
- Re: Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/26/2012
- Re: Re: Re: Re: [cgal-discuss] Static vs Shared, Laurent Rineau (CGAL/GeometryFactory), 07/27/2012
- Re: Re: Re: Re: [cgal-discuss] Static vs Shared, Panagiotis Foteinos, 07/27/2012
