- To:
- Subject: Re: Re: Re: [cgal-discuss] 3D Mesh+intersections+Eigen
- Date: Fri, 03 Aug 2012 16:29:12 +0200
Le vendredi 03 août 2012 15:54:43
a écrit :
> <Do you compile your program using a 64 bits compiler? What is the expected
> <size of matrix for 2971971 vertices ?
> Yes, I compile using a 64 bits compiler.
> How I can find the expected size of the matrix?
You gave us the number of vertices, but not the number of lines.
In a previous message you said "matrix of size (Number of vertexes X Number
of
lines)". Maybe that number is so huge that even 20Go of memory was not enough.
Laurent Rineau, PhD
- Re: [cgal-discuss] 3D Mesh+intersections+Eigen, Laurent Rineau (CGAL/GeometryFactory), 08/01/2012
- <Possible follow-up(s)>
- Re: [cgal-discuss] 3D Mesh+intersections+Eigen, cecilia, 08/03/2012
- Re: Re: [cgal-discuss] 3D Mesh+intersections+Eigen, Laurent Rineau (CGAL/GeometryFactory), 08/03/2012
- Re: Re: [cgal-discuss] 3D Mesh+intersections+Eigen, cecilia, 08/03/2012
- Re: Re: Re: [cgal-discuss] 3D Mesh+intersections+Eigen, Laurent Rineau (CGAL/GeometryFactory), 08/03/2012
- Re: Re: Re: [cgal-discuss] 3D Mesh+intersections+Eigen, cecilia, 08/03/2012
