cgal-discuss - RE: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8
  • To: <>
  • Subject: RE: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8
  • Date: Mon, 13 Aug 2012 00:16:47 +1200
  • Importance: Normal
Hi Andreas,
I choosed 64 bit when installing CGAL 3.9 (VS2010, boost 1.47 and Qt 4.7.2), but when I opened the project generated by CMake 2.8.7, there is only 'Win32' platform, I added the new 'x64' platform and build the solution, all 505 projects the following error displayed:
fatal error LNK1112: module machine type 'x64' conflicts with target machine type 'X86'
How did you solve this prolem?
Thanks,
Zhanghong Tang
> Date: Wed, 29 Feb 2012 12:26:15 +0100
> From:
> To:
> Subject: Re: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8
> On 29/02/2012 12:09, JoeTaylor wrote:
> > As far as I know there is only one gmp lib included in the installation:
> > ...\CGAL-3.9\auxiliary\gmp\libgmp-10.lib
> > Could it be, that this is a 32bit gmp not 64bit, that's why it is having
> > trouble linking it? Is it possible to use generate a 64bit gmp with cmake?
> When you install CGAL with the installer, you have the choice between
> 64 ans 32 bit.
> andreas
> > Thank you!
> > View this message in context: http://cgal-discuss.949826.n4.nabble.com/Gmp-link-error-CGAL-3-9-VS2010-boost-1-47-Qt-4-8-tp4341245p4431197.html
> > Sent from the cgal-discuss mailing list archive at Nabble.com.
> Andreas Fabri, PhD
> Chief Officer, GeometryFactory
> Editor, The CGAL Project
> phone: +33.492.954.912 skype: andreas.fabri
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
