Re: RE: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8
- To:
- Subject: Re: RE: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8
- Date: Thu, 16 Aug 2012 13:50:05 +0200
Le lundi 13 août 2012 00:16:47 Zhanghong Tang a écrit :
> Hi Andreas,
> I choosed 64 bit when installing CGAL 3.9 (VS2010, boost 1.47 and Qt 4.7.2),
> but when I opened the project generated by CMake 2.8.7, there is only
> 'Win32' platform, I added the new 'x64' platform and build the solution,
> all 505 projects the following error displayed:
> fatal error LNK1112: module machine type 'x64' conflicts with target machine
> type 'X86'
> How did you solve this prolem?
During the configuration, using CMake, you must choose a generator that
creates a project for x64. If you use VS2010, you must choose the generator
"Visual Studio 10 Win64". Projects created by CMake are not multi-
architecture.
Laurent Rineau, PhD
- RE: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8, Zhanghong Tang, 08/12/2012
- Re: RE: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8, Laurent Rineau (CGAL/GeometryFactory), 08/16/2012
