cgal-discuss - Re: [cgal-discuss] Cannot Build CGAL_Core
  • To:
  • Subject: Re: [cgal-discuss] Cannot Build CGAL_Core
  • Date: Sat, 18 Aug 2012 21:11:49 +0200
Le samedi 18 août 2012 10:45:29 Zakai a écrit :
> Hello,
> I'm trying to build the library CGAL to use it with visual studio.
> I'm following these tutorial :
> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-
> windows.
> When I'm doing this, everything compile correctly except CGAL_Core.
> - Compile ALL_BUILD project both in Debug and Release.
> - All CGAL libraries should be under the lib directory.
> ------ Build started: Project: CGAL_Core, Configuration: Debug Win32 ------
> Build started 8/8/2012 5:43:40 PM.
> InitializeBuildStatus:
> Touching "CGAL_Core.dir\Debug\CGAL_Core.unsuccessfulbuild".
> CustomBuild:
> All outputs are up-to-date.
> ClCompile:
> ResourceCompile:
> ManifestResourceCompile:
> Link:
> Creating library C:/Program Files
> (x86)/CGAL-4.0.2/lib/Debug/CGAL_Core-vc100-mt-gd-4.0.2.lib and object
> C:/Program Files (x86)/CGAL-4.0.2/lib/Debug/CGAL_Core-vc100-mt-gd-4.0.2.exp
> all_files.obj : error LNK2019: unresolved external symbol __imp____gmpz_init
> referenced in function "public: __thiscall
> CORE::BigIntRep::BigIntRep(void)" (??0BigIntRep@CORE@@QAE@XZ)
The CGAL_Core project should link with GMP. Do you have a problem with your
GMP installation?
Laurent Rineau, PhD
