- To:
- Subject: [cgal-discuss] Re: Cannot Build CGAL_Core
- Date: Sun, 19 Aug 2012 08:26:02 -0700 (PDT)
May be it's going to help you, I have a mac book pro 13. I'm running windows
7 64 bits on it virtually, do you think this could be linked with my problem
? And about cmake the only modification I did is following this instructions
- Click on "Add Entry"
Set name to BOOST_ROOT
Set type to "Path"
Set value to C:/Program Files/boost/boost_1_47
Click OK
- Click on "Add Entry" again
Set name to QT_QMAKE_EXECUTABLE
Set type to "Path"
Set value to C:/Qt/4.8.1/bin/qmake.exe
Click OK
Thank you for your time.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Cannot-Build-CGAL-Core-tp4655731p4655737.html
- [cgal-discuss] Cannot Build CGAL_Core, Zakai, 08/18/2012
- Re: [cgal-discuss] Cannot Build CGAL_Core, Laurent Rineau (CGAL/GeometryFactory), 08/18/2012
- [cgal-discuss] Re: Cannot Build CGAL_Core, Zakai, 08/18/2012
- Re: [cgal-discuss] Re: Cannot Build CGAL_Core, Laurent Rineau (CGAL/GeometryFactory), 08/19/2012
- [cgal-discuss] Re: Cannot Build CGAL_Core, Zakai, 08/19/2012
- Re: [cgal-discuss] Re: Cannot Build CGAL_Core, Sebastien Loriot (GeometryFactory), 08/19/2012
