cgal-discuss - Re: [cgal-discuss] CGAL newbie
  • To:
  • Subject: Re: [cgal-discuss] CGAL newbie
  • Date: Thu, 23 Aug 2012 16:58:29 +0200
On 08/22/2012 11:49 AM,
wrote:
Hi All,
I am contemplating using CGAL for a research project that involves making a
Delaunay triangulation. I had 2 questions to start with.
1. Is it possible to compute the interior angles for each triangle? And also
the slope/di-hedral angle each triangle makes to the x-y plane?
You can have access to each facets, so writing what you want should not
be complicated.
2. Is it possible to generate my own graph representation using the i-graph C
library once I have a Delaunay triangulation?
Nothing in CGAL will do it directly.
However, CGAL provides an interface to boost graph which might
help doing it.
See here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/BGL_ref/Class_graph_traits.html
Sebastien.
Thanks,
Manu
