- To:
- Subject: Re: [cgal-discuss] CGAL newbie
- Date: Fri, 24 Aug 2012 11:25:30 +0200
Le 23/08/12 16:58, Sebastien Loriot (GeometryFactory) a écrit :
On 08/22/2012 11:49 AM,
wrote:
Hi All,
I am contemplating using CGAL for a research project that involves
making a
Delaunay triangulation. I had 2 questions to start with.
1. Is it possible to compute the interior angles for each triangle?
And also
the slope/di-hedral angle each triangle makes to the x-y plane?
You can have access to each facets, so writing what you want should not
be complicated.
Right. Let me mention that there are also a few functions in CGAL for computing angles.
2. Is it possible to generate my own graph representation using the
i-graph C
library once I have a Delaunay triangulation?
Nothing in CGAL will do it directly.
But here again, CGAL gives you access to all necessary information about cells, adjacencies, incidence, etc, which will allow you to generate a graph in another library.
However, CGAL provides an interface to boost graph which might
help doing it.
See here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/BGL_ref/Class_graph_traits.html
indeed
Monique
Sebastien.
Thanks,
Manu
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] CGAL newbie, manu.kaul, 08/22/2012
- Re: [cgal-discuss] CGAL newbie, Sebastien Loriot (GeometryFactory), 08/23/2012
- Re: [cgal-discuss] CGAL newbie, Monique Teillaud, 08/24/2012
