cgal-discuss - [cgal-discuss] Is it the right way to do that
  • To:
  • Subject: [cgal-discuss] Is it the right way to do that
  • Date: Tue, 4 Sep 2012 05:24:52 -0700 (PDT)
Hi everybody,
I have a question before going in depth in my code.
I have a set of 3D points in the same plane. With the CGAL framework, it's
impossible to do 3D polygons so I have chosen to do a 3D polyhedron with my
3D points. The result is on this picture :
http://cgal-discuss.949826.n4.nabble.com/file/n4655791/poly1.png
The construction of this polyhedron is :
template <class HDS>
void Build_polygon<HDS>::operator()( HDS& hds )
if (!polygon)
return;
// Postcondition: `hds' is a valid polyhedral surface.
CGAL::Polyhedron_incremental_builder_3<HDS> B( hds, true);
typedef typename HDS::Vertex Vertex;
typedef typename Vertex::Point Point;
B.begin_surface( polygon->points().count(), 1, 0); //Surface with
several points
foreach (RPoint3d* p, polygon->points()) { //iterates all points
B.add_vertex(Point(p->x(), p->y(), p->z()));
B.begin_facet();
for (int i = 0; i < polygon->points().count(); i++)
B.add_vertex_to_facet( i);
B.end_facet();
B.end_surface();
Now I need to have the intersection between this polyhedron and a plane :
Tree tree(polyhedron()->facets_begin(),polyhedron()->facets_end());
Point p((FT)0.0, (FT)0.0, z);
Plane plane(p,normal);
std::list<Object_and_primitive_id> intersections;
tree.all_intersections(plane,std::back_inserter(intersections));
This code crash but if I declare several polyhedron of 3 points instead, the
intersection works.
The result of the intersection I need is a segment.
So to resume, is the polyhedron the best way to have a segment as result ?
Does exists another class instead ?
Laurent Rineau said to me in other topic that I can do 3D triangulation of
my polyhedron. The result is not that I am expected (see the following
picture) :
http://cgal-discuss.949826.n4.nabble.com/file/n4655791/poly2.png
The triangulation gives facets at the exterior of my polehydron.
The good news is that the intersections algorithm works.
Thanks in advance for your advices
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Is-it-the-right-way-to-do-that-tp4655791.html
