- To:
- Subject: Re: [cgal-discuss] Is it the right way to do that
- Date: Wed, 05 Sep 2012 07:27:02 +0200
On 09/04/2012 02:24 PM, babaOroms wrote:
Hi everybody,If the polyhedron is not triangulated and Tree::Primitive::Datum is a
I have a question before going in depth in my code.
I have a set of 3D points in the same plane. With the CGAL framework, it's
impossible to do 3D polygons so I have chosen to do a 3D polyhedron with my
3D points. The result is on this picture :
http://cgal-discuss.949826.n4.nabble.com/file/n4655791/poly1.png
The construction of this polyhedron is :
template<class HDS>
void Build_polygon<HDS>::operator()( HDS& hds )
if (!polygon)
return;
// Postcondition: `hds' is a valid polyhedral surface.
CGAL::Polyhedron_incremental_builder_3<HDS> B( hds, true);
typedef typename HDS::Vertex Vertex;
typedef typename Vertex::Point Point;
B.begin_surface( polygon->points().count(), 1, 0); //Surface with
several points
foreach (RPoint3d* p, polygon->points()) { //iterates all points
B.add_vertex(Point(p->x(), p->y(), p->z()));
B.begin_facet();
for (int i = 0; i< polygon->points().count(); i++)
B.add_vertex_to_facet( i);
B.end_facet();
B.end_surface();
Now I need to have the intersection between this polyhedron and a plane :
Tree tree(polyhedron()->facets_begin(),polyhedron()->facets_end());
Point p((FT)0.0, (FT)0.0, z);
Plane plane(p,normal);
std::list<Object_and_primitive_id> intersections;
tree.all_intersections(plane,std::back_inserter(intersections));
This code crash but if I declare several polyhedron of 3 points instead, the
intersection works.
triangle, then this can not work.
Note that the intersection might be several segments.
The result of the intersection I need is a segment.
What you need to use is a AABB_tree with AABB_polyhedron_segment_primitive as primitive [0].
Then compute all the intersections. You will have a set of points
(and segments if the plane contains a segment of the polygon).
You can sort the points using a dot product with the left-down most
point.
Then you can get the segments using adjacent points, taking care that the plane might go through a segment endpoint
[0] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree_ref/Class_AABB_polyhedron_segment_primitive.html
Sebastien.
So to resume, is the polyhedron the best way to have a segment as result ?
Does exists another class instead ?
Laurent Rineau said to me in other topic that I can do 3D triangulation of
my polyhedron. The result is not that I am expected (see the following
picture) :
http://cgal-discuss.949826.n4.nabble.com/file/n4655791/poly2.png
The triangulation gives facets at the exterior of my polehydron.
The good news is that the intersections algorithm works.
Thanks in advance for your advices
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Is-it-the-right-way-to-do-that-tp4655791.html
- [cgal-discuss] Is it the right way to do that, babaOroms, 09/04/2012
- Re: [cgal-discuss] Is it the right way to do that, Sebastien Loriot (GeometryFactory), 09/05/2012
- [cgal-discuss] Re: Is it the right way to do that, babaOroms, 09/05/2012
