cgal-discuss - Re: Re: [cgal-discuss] Problem with gmp linking with 64-bit Windows 7 & Visual Studio 2010 and CGAL 4.0.2
  • To:
  • Subject: Re: Re: [cgal-discuss] Problem with gmp linking with 64-bit Windows 7 & Visual Studio 2010 and CGAL 4.0.2
  • Date: Sat, 08 Sep 2012 18:11:18 +0200
Le mercredi 05 septembre 2012 11:19:34 Karen Daniels a écrit :
> I am also unable to build the examples and demos, so something is going
> wrong early on as well. I have installed earlier versions of CGAL
> numerous times on other platforms and never had this amount of trouble.
> Here is what cmake is complaining about with regards to examples and
> demos. It appears to be adding duplicative prefixes to directory paths
> and I don't know why:
> CMake Error at C:/Program Files (x86)/CMake
> 2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:64 (FILE):
> file problem creating directory: C:/Program Files
> (x86)/CGAL-4.0.2/demo/C:/Program Files (x86)/CGAL-4.0.2/demo/Alpha_shapes_2
> Call Stack (most recent call first):
> 2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:202 (QT4_MAKE_OUTPUT_FILE)
> demo/Alpha_shapes_2/CMakeLists.txt:40 (qt4_add_resources)
I think you get that error because you are trying to build CGAL libraries
with
CMAKE_BINARY_DIR inside C:\Program Files (x86)\. You can install CGAL sources
here, but your compilation tree (the so-called CMAKE_BINARY_DIR) must be
somewhere else, for example in a sub-directory of your "My Documents" folder.
Laurent Rineau, PhD
