cgal-discuss - Re: [cgal-discuss] Problem with gmp linking with 64-bit Windows 7 & Visual Studio 2010 and CGAL 4.0.2
  • To:
  • Subject: Re: [cgal-discuss] Problem with gmp linking with 64-bit Windows 7 & Visual Studio 2010 and CGAL 4.0.2
  • Date: Sat, 08 Sep 2012 12:45:33 -0400
Thank you. I will try that.
- Karen
On 9/8/2012 12:11 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
Le mercredi 05 septembre 2012 11:19:34 Karen Daniels a écrit :
I am also unable to build the examples and demos, so something is going
wrong early on as well. I have installed earlier versions of CGAL
numerous times on other platforms and never had this amount of trouble.
Here is what cmake is complaining about with regards to examples and
demos. It appears to be adding duplicative prefixes to directory paths
and I don't know why:
CMake Error at C:/Program Files (x86)/CMake
2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:64 (FILE):
file problem creating directory: C:/Program Files
(x86)/CGAL-4.0.2/demo/C:/Program Files (x86)/CGAL-4.0.2/demo/Alpha_shapes_2
Call Stack (most recent call first):
2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:202 (QT4_MAKE_OUTPUT_FILE)
demo/Alpha_shapes_2/CMakeLists.txt:40 (qt4_add_resources)
I think you get that error because you are trying to build CGAL libraries with
CMAKE_BINARY_DIR inside C:\Program Files (x86)\. You can install CGAL sources
here, but your compilation tree (the so-called CMAKE_BINARY_DIR) must be
somewhere else, for example in a sub-directory of your "My Documents" folder.
Karen Daniels, Ph.D.
Associate Professor
Department of Computer Science
University of Massachusetts Lowell
One University Avenue
Olsen Hall, Room 216
Lowell, MA 01854
Phone: 978-934-3631
Fax: 978-934-3551
Email:
URL: http://www.cs.uml.edu/~kdaniels
