cgal-discuss - [cgal-discuss] Linking problems newbie
  • To:
  • Subject: [cgal-discuss] Linking problems newbie
  • Date: Tue, 11 Sep 2012 08:38:29 -0700 (PDT)
Hello I installed cgal with macports and I was triying to run this example I
found:
#include <iostream>
#include <CGAL/convex_hull_2.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_2 Point_2;
int main()
Point_2 points[5] = { Point_2(0,0), Point_2(10,0), Point_2(10,10),
Point_2(6,5), Point_2(4,1) };
Point_2 result[5];
Point_2 *ptr = CGAL::convex_hull_2( points, points+5, result );
std::cout << ptr - result << " points on the convex hull" << std::endl;
return 0;
Nevertheless I get this linking errors .I am using xcode 4.3.2 and os 10.7.4
. Regards
Undefined symbols for architecture x86_64:
"___gmpq_init", referenced from:
CGAL::Gmpq_rep::Gmpq_rep()in main.o
"___gmpq_clear", referenced from:
CGAL::Gmpq_rep::~Gmpq_rep()in main.o
"___gmpq_set_d", referenced from:
CGAL::Gmpq::Gmpq(double)in main.o
"___gmpq_sub", referenced from:
CGAL::Gmpq::operator-=(CGAL::Gmpq const&)in main.o
"___gmpq_mul", referenced from:
CGAL::Gmpq::operator*=(CGAL::Gmpq const&)in main.o
"___gmpq_cmp", referenced from:
CGAL::Gmpq::operator<(CGAL::Gmpq const&) constin main.o
"___gmpq_equal", referenced from:
CGAL::Gmpq::operator==(CGAL::Gmpq const&) constin main.o
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Linking-problems-newbie-tp4655838.html
