- To: ,
- Subject: Re: [cgal-discuss] Linking problems newbie
- Date: Wed, 12 Sep 2012 01:17:03 +0900
Hi Sebitas,
Maybe you can refer to this website: http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
and follows the settings in number 7) Customizing env.
Hope this helps.
Best Regards,
Saw
Saw
On Wed, Sep 12, 2012 at 12:40 AM, Philipp Moeller <> wrote:
You are not linking to GMP although macports ships a gmp enabled CGALsebitas <> writes:
> Hello I installed cgal with macports and I was triying to run this example I
> found:
> #include <iostream>
> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> #include <CGAL/convex_hull_2.h>
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> typedef K::Point_2 Point_2;
> int main()
> Point_2 points[5] = { Point_2(0,0), Point_2(10,0), Point_2(10,10),
> Point_2(6,5), Point_2(4,1) };
> Point_2 result[5];
> Point_2 *ptr = CGAL::convex_hull_2( points, points+5, result );
> std::cout << ptr - result << " points on the convex hull" << std::endl;
> return 0;
> Nevertheless I get this linking errors .I am using xcode 4.3.2 and os 10.7.4
> . Regards
> Undefined symbols for architecture x86_64:
> "___gmpq_init", referenced from:
> CGAL::Gmpq_rep::Gmpq_rep()in main.o
> "___gmpq_clear", referenced from:
> CGAL::Gmpq_rep::~Gmpq_rep()in main.o
> "___gmpq_set_d", referenced from:
> CGAL::Gmpq::Gmpq(double)in main.o
> "___gmpq_sub", referenced from:
> CGAL::Gmpq::operator-=(CGAL::Gmpq const&)in main.o
> "___gmpq_mul", referenced from:
> CGAL::Gmpq::operator*=(CGAL::Gmpq const&)in main.o
> "___gmpq_cmp", referenced from:
> CGAL::Gmpq::operator<(CGAL::Gmpq const&) constin main.o
> "___gmpq_equal", referenced from:
> CGAL::Gmpq::operator==(CGAL::Gmpq const&) constin main.o
> ld: symbol(s) not found for architecture x86_64
> collect2: ld returned 1 exit status
installation. To add an additional library within XCode:
Go to Project -> Edit Project -> Linking -> Other Linker Flags
and add -L/path/to/gmp/lib/ -lgmp
Best Regards,
Saw Seow Hui
Lecturer
Faculty of Information and Communication Technology
Department of Computer Science
University Tunku Abdul Rahman (UTAR)
Jalan Universiti, Bandar Barat,
31900 Kampar, Perak.
- [cgal-discuss] Linking problems newbie, sebitas, 09/11/2012
- Re: [cgal-discuss] Linking problems newbie, Philipp Moeller, 09/11/2012
- Re: [cgal-discuss] Linking problems newbie, Seow Hui, Saw, 09/11/2012
- Re: Re: [cgal-discuss] Linking problems newbie, Laurent Rineau (CGAL/GeometryFactory), 09/11/2012
- [cgal-discuss] Re: Linking problems newbie, sebitas, 09/11/2012
