[cgal-discuss] Bug? with boundary condition when creating exterior offset polygon
- To:
- Subject: [cgal-discuss] Bug? with boundary condition when creating exterior offset polygon
- Date: Tue, 11 Sep 2012 12:11:26 -0700 (PDT)
Hello,
I have been attempting to use CGAL for polygon offsetting (both interior and
exterior) for a few days now. I ran into a problem last night when creating
an exterior offset polygon for the following polygon with points:
(0, 0), (700, 0), (700, 600), (0, 600), (0, 300), (300, 300), (300, 400),
(600, 400), (600, 100), (300, 100), (300, 200), (0, 200)
When I attempt to offset this by 40, I get the correct result of:
(-40, -40), (740, -40), (740, 640), (-40, 640), (-40, 260), (340, 260),
(340, 360), (560, 360), (560, 140), (340, 140), (340, 240), (-40, 240)
However, when I attempt to offset by 50, I should get a polygon with outer
boundary of:
(-50, -50), (750, -50), (750, 650), (-50, 650), (-50, 250)
and a hole of:
(350, 150), (350, 250), (350, 350), (550, 350), (550, 150)
Instead, I get a simple polygon: (-50, -50), (750, -50), (750, 650), (-50,
650), (-50, 250) ... so I never get the hole. Strangely enough, as soon as I
increase the offset amount to 50.0000001 for example, the hole shows up
again. This seems to indicate there may be a bug in handling these boundary
conditions.
The code I am using is largely copied from:
http://www.cgal.org/Manual/latest/examples/Straight_skeleton_2/Low_level_API.cpp
to do exterior polygon offsetting for polygons with holes (or that would
result in holes).
The code I am using is below, with only the appropriate includes, typedefs
and the one relevant function shown:
I have tried using both the Epick and Epeck kernels and both give the same
results. I would appreciate any help in debugging this further, or if this
really is a bug, if there's some patch that can be applied.
Thanks!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-with-boundary-condition-when-creating-exterior-offset-polygon-tp4655843.html
- [cgal-discuss] Bug? with boundary condition when creating exterior offset polygon, Nigel Drego, 09/11/2012
- [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon, Nigel Drego, 09/11/2012
- [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon, Nigel Drego, 09/13/2012
- Re: [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon, Sebastien Loriot (GeometryFactory), 09/13/2012
- [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon, Nigel Drego, 09/17/2012
