[cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon
- To:
- Subject: [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon
- Date: Wed, 12 Sep 2012 21:34:30 -0700 (PDT)
Here is a compileable example. Simply changing the following line:
to
demonstrates the problem. In the first case, the output is:
but in the second case, it is:
Any help would be appreciated. Thanks.
http://cgal-discuss.949826.n4.nabble.com/file/n4655847/Low_level_API.cpp
Low_level_API.cpp
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-with-boundary-condition-when-creating-exterior-offset-polygon-tp4655843p4655847.html
- [cgal-discuss] Bug? with boundary condition when creating exterior offset polygon, Nigel Drego, 09/11/2012
- [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon, Nigel Drego, 09/11/2012
- [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon, Nigel Drego, 09/13/2012
- Re: [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon, Sebastien Loriot (GeometryFactory), 09/13/2012
- [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon, Nigel Drego, 09/17/2012
