cgal-discuss - Re: [cgal-discuss] dD Spatial Searching, sort points.
  • To:
  • Subject: Re: [cgal-discuss] dD Spatial Searching, sort points.
  • Date: Mon, 01 Oct 2012 14:30:56 +0200
On 09/20/2012 10:53 AM, aptypr wrote:
In the example for k neighbor searching I found that
CGAL::Orthogonal_k_neighbor_search return points, sorted by distance of
initial point, are there ways to sort point in process of searching? I want
to sort points by x, and if x are the same, by y. Right now I search k
neighbors, and sort them, which is expensive.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/dD-Spatial-Searching-sort-points-tp4655879.html
As documented in [1], the last function argument control whether the sequence of points need to be sorted.
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching_ref/Class_Orthogonal_k_neighbor_search.html
